Old 09-02-2005, 03:40 PM   #1 (permalink)
DM1
DM1's Avatar
Brake question?
I am taking my brakes off and replacing them with new ones but i have a problem with the the brake piston. When i put the new pads on the brake does fit and i can't seem to make the piston go back to make room. Can anyone help me with this problem the help is most appreciated.
DM1 is offline   Reply With Quote
Old 09-02-2005, 04:50 PM   #2 (permalink)
DM;
A "C" clamp placed squarely over the piston will convince it that it's time to retract. Just don't get carried away and sink it back further than necessary. All you need is the clearance for the new pad and the rotor. Get carried away in you efforts and you're looking at unnecessary problems.
Also, if your pads are being replaced because of considerable wear, remember to pop the cap on the resevoir and place a clean, absorbant rag there to take any overflow of brake fluid that will be displaced when you push the pistons back. If you've gotten the car serviced and the fluid was down a bit, some well-meaning mech may have topped it up, in which case your pushing the pistons back is going to cause the extra fluid to leave a trail like a paint-eating slug. Don't forget the rag.
Need Help Adjusting Parking Brake tien2cool News & Special Announcements 3 05-05-2007 04:46 PM
Stock Brake Life bladerunner Wheels / Tires / Suspension 9 04-29-2007 10:34 AM
Gear brake or not wowowox All Other Honda S2000 Related Discussions 6 02-18-2006 11:09 PM
Brake Upgrade Leebo All Other Honda S2000 Related Discussions 4 10-20-2005 08:50 AM
Please help with brake noob question... youngpre All Other Honda S2000 Related Discussions 1 07-04-2004 09:40 PM
