Old 11-01-2005, 05:16 PM   #1 (permalink)
ghenders
Slightly grinds second gear when cold
I have a 05' S2000 that I bought new approximately 2 months ago with 2500 miles on it. I have noticed that when it is cold after sitting overnight, in the morning going from 1st to 2nd you can feel that the syncro is not quite doing the job. Once the car is warm (approx. 10 miles) it shifts into 2nd like it should.
Does anyone else have this symptom? The car only had 56 miles when it was delivered. Is it possible some moron missed 2nd gear during a demo drive and trashed the 2nd gear syncro?
Thx
ghenders is offline   Reply With Quote
Old 11-01-2005, 06:25 PM   #2 (permalink)
Warm oil always allows things to work better than cold oil. Give 'er a chance to warm up n' she'll be fine.
Old 12-18-2005, 05:13 PM   #3 (permalink)
silverstone05
same problem
yeah i have the same symptom on my 05 even when it was brand new. everyone told me it was natural.
thanks
faheem
silverstone05 is offline   Reply With Quote
Old 12-18-2005, 06:57 PM   #4 (permalink)
wowowox
too bad everyone has the same problem, otherwise this car will be a very good roadster.. btw the problem will not get better eventhough u have more miles on ur car. some people said that the problem is solved after chnaging the transmission oil.. maybe some of you can test it out, i wish i can solve this problem tooo ...
Old 12-19-2005, 06:24 AM   #5 (permalink)
passmans2kNY
passmans2kNY's Avatar
just because the engine is warm doesnt mean the clutch is, like u said its fine after 10 mins, just shift easy for the first 5 mins
Old 12-19-2005, 06:46 AM   #6 (permalink)
jim
Send a message via AIM to jim Send a message via MSN to jim
goto a good parts shop and get an oil that it good for cold weather... the oil inthere is probably ment for warm weather because its meant to be a summer car. royal purple synthetic is supposed to be good... talk to a dealer first... do they still use sae oil in the tranny? double clutch till the tranny fluid get moving
jim is offline   Reply With Quote
Gear grind john Engine Tech / Drivetrain 5 08-04-2007 10:47 PM
1st gear (-n0-) All Other Honda S2000 Related Discussions 4 04-07-2006 11:48 AM
Gear brake or not wowowox All Other Honda S2000 Related Discussions 6 02-18-2006 11:09 PM
Second Gear Clunkiness slimjim8201 All Other Honda S2000 Related Discussions 1 06-23-2005 06:26 AM
cold rev. limiter anyone driver All Other Honda S2000 Related Discussions 6 01-04-2005 07:59 AM
