What would you buy with around ?5000 ($9000) ?
How would you improve an S2000 (2005) if given, say, ?5000 or $9000 to spend on it ?
do it
love fab gt-1 turbo kit, www.lovefab.com, plus a exedy hyper carbon single plate clutch, mabye cop those jic magic flt a2s(coil overs) if u got any money left
www.lovefab.com there was a , on the end of the one b4, it will work now
I wonder how a turbo application would affect the revability?
Presumably the engine would peak earlier and the power and torque would drop away after 7000 rpm or so? |
Revability? Not much. There is minimal "drag" on the engine. A little more backpressure as a result of the turbo, but revability shouldn't change much if at all.
The engine will still peak high, however, there is almost constant torque from about 3800 rpm to redline. This creates a very nice linear power delivery (once in boost). The on/off power aspect will still be evident but will be caused by the presence or lack of boost rather than vtec. The base Lovefab kit makes more horsepower at 6000 rpm than a stock motor makes a redline |
No. Have a look at a dyno chart.
#8 (permalink) | |
Sorry I'm at work atm.
I meant "No" to the revability of the engine and peak power. As slimjim pointed out when he posted at the same time as me :P Here's a dynochart: http://www.lovefab.com/cody/Codys%20S2k/gt1dyno.JPG |
What bhp and ft/lbs does that equate to?
Stock I believe are 237 and 145 at crank. |
A stock S2000 will produce a little less than 200 hp at the rear wheels. Give or take 15 horsepower depending on the dyno and conditions. On the same dyno, on the same day, with the same car, the base lovefab kit should put out in excess of 100 horsepower over stock. So that equates to around 300+ horsepower at the rear wheels or 355+ horsepower at the crank (assuming an 18.5% driveline loss). This should also get you an average of around 180 ft-lb of torque from 5000 to 9000 rpm. That equates to about 213+ ft-lb at the crank over almost half of the engine's range.
This is the BASIC kit as well. It only goes up from here. And when I say up, I mean WAY up. |
Just for comparison, here is a scan of my Comptech SC running stock boost with stock header, cat delete and Comptech exhaust. WAY more peaky than the turbo. (red is stock)
http://www.s2ki.com/forums/index.php...age&img=191894 -edit for some reason it won't let me embed the image, so click the link |
Im doing the CT SC as soon as I can. I am ITCHING to get one on my car. Turbos are awesome, don't get me wrong, but I don't want any hassles and "turbo" and "hassle" go hand in hand.
ok first off that dyno sheet for the love fab isnt running high boost at all, i think it was something around 6 or 7 psi, that kit can produce so much more hp its not even funny, just with a head gasket you can lower the compression to 9 to 1, which you can go up to around 14 psi, your up in the 400 hp to thr wheels, and second of all, i know people with s2000s, and they all go the sc way, i dunno, just too many people shy away from a turbo, there is so much more potential, and its not a hassel if u know what your doing and simply maintain your engine/turbo setup, plus tuning lol
I think the problem isn't you (i.e. the driver) knowing what you're doing, it's the guy wrenching on your car, setting up the ECU, interpreting the data from the dyno and the wideband... do THEY know what they're doing? If they screw up, who buys the new engine? What do you drive while the engine is being rebuilt? Not that these things are going to happen 100% of the time with a turbo, but what if?
#16 (permalink) | |
#17 (permalink) |
yea thats what my rx7 did to my wallet, destroyed it, I would say go with the turbo kit just bc everyone does the supercharger, i dunno its just me but i hate having the same shit as other people, plus like u mentioned u might get sick of it knowing the gt-1 kit is the phatness
#18 (permalink) |
I am kind of hoping that the GT1 kit is so good that once properly tuned, it will last me the remainder of my time with the car. Probably another 4 years or so. The quality of the kit is superb, the turbo itself should have no trouble lasting that long (the Garrett GT series is an awesome product line). With routine maintenence I think the kit would definitely be in for the long haul. When it is all said and done, excluding tuning, the kit would probably be nearly $8,000
That also doesnt include the new clutch/PP you would need to hold the power. I still want it SO BADLY...single tear... |
#19 (permalink) |
i know i want it so bad, i check the website and see the same thing everyday, what i need is 10,000 $ then ill be good, yea you really cant get much better than this turbo kit, if the engine is built you can produce huge hp numbers with that kit
#20 (permalink) |
I'm not even looking for HUGE numbers though. The GT1 kit with a safe and mild tune will still produce well over 300 whp and it will make more torque at 4000 RPM than the stock motor makes at any RPM. It exceeds the stock max horsepower at 5500 rpm. That is rediculous. You could short shift at 6000 rpm and it would be like you were redlining in a stock car. And you still have 3500 more rpm on top to explore if the guy in the Mustang next to you is shooting dirty looks
All of this and the kit has exceptional quality. I am also addictied to the sound of a turbo BOV. Seriously the coolest sound a car can make. |
#21 (permalink) | |
#22 (permalink) | ||
| 9000 rpm... is it safe? | S2000Crazy | Engine Tech / Drivetrain | 8 | 02-01-2007 08:00 PM |
| Where to buy the SC | ultralite S2K | Forced Induction / Nitrous | 1 | 01-29-2007 07:42 PM |
| about to buy one | my87300zxt | All Other Honda S2000 Related Discussions | 2 | 08-23-2006 03:12 PM |
| $5000 to Spend | Plinko | All Other Honda S2000 Related Discussions | 8 | 11-06-2005 06:12 PM |
| Should I buy new or used? | Brutewes | All Other Honda S2000 Related Discussions | 4 | 06-28-2003 03:12 AM |
