Old 11-14-2005, 12:43 PM   #1 (permalink)
JB
S2000 changes
Does anyone know where I can find information about the changes that were made, and when, to the S2000 for UK modles. I understand that there have been 4 versions but know nothing more than that.
Thanks
JB is offline   Reply With Quote
Old 11-14-2005, 01:36 PM   #2 (permalink)
Esstoothou
Until someone posts the changes in detail let me say that the 2004 model is much better than the previous ones.
Esstoothou is offline   Reply With Quote
Old 11-15-2005, 08:22 AM   #3 (permalink)
RCduck7
Later models are even more reliable and comfortable but it's the early model from 99' to 02' that is most true on how they intented it to be as a spotscar though.
Old 11-15-2005, 09:58 AM   #4 (permalink)
JB
Cheers - I will probably be getting an earlier example... Just wondering if more cash for newer car gets better ride/engine/toys etc.....
Old 11-15-2005, 10:04 AM   #5 (permalink)
Esstoothou
The 2004-on car is way better. Look it up and see how much they changed the car for the better.
The earlier car did not handle for a start.
Old 11-15-2005, 10:37 AM   #6 (permalink)
RCduck7
You have to be a bit more of a skilled driver for the earlier models but they are more fun, dunno what articles you read.
Old 11-15-2005, 11:30 AM   #7 (permalink)
passmans2kNY
passmans2kNY's Avatar
they all handle amazing, the older ones have stiffer suspension
Old 11-15-2005, 05:37 PM   #8 (permalink)
MattG
Here's some links that should answer your question:
MY changes
http://forums.s2ki.com/forums/index....owtopic=161997
Differences between USDM/JDM/EDM
http://forums.s2ki.com/forums/index....owtopic=205451
Basically (apart from colour combos/choices):
01 model had a clock on the radio.
The 02 model had a glass rear window and some more minor cosmetic changes (eg chrome rings). ECU slightly different.
04 - revised suspension geometry, gear ratios, US got 2.2L motor, more cosmetic changes (eg cupholder different), 17" wheels.
Old 11-16-2005, 04:00 AM   #9 (permalink)
Esstoothou
I just asked the Honda mechanic at our local dealer (he also races cars) and he said that the late-model S2000 is overall the better car and by a distance.
Bottom line.
A firm like Honda are hardly going to spend lots of money changing it quite a lot, without making it better !!!
Old 11-16-2005, 04:01 AM   #10 (permalink)
Esstoothou
3 people in my area, who have traded up for the late model all say how much better the new car is.
Old 11-16-2005, 10:17 AM   #11 (permalink)
RCduck7
It depends on how you look to the changes but softer suspension isn't going make any faster or racelike in the bends.
They made the newer models softer, for some this will be better in terms of daily use i guess.
Old 11-16-2005, 11:34 AM   #12 (permalink)
The most noticeable changes are between the '03 n' '04 model years.
I don't find it as one is "better" than the other. One (the '04 n' later model)is definitely more "forgiving" than the other.
If you enjoy ridin' on the edge in a twitchier, more responsive car the earlier Stewie's the obvious choice. If you'd rather have that cushion of extra traction that allows you to dance on that same edge without quite as much worry about when the back end's gonna have a mind to race the front end to the next corner, well, then you've just selected the later version.
Which is "better"? To each his/her own. I can't see where anyone could gripe about either one, as time spent with either will have you adjustin' your drivin' n' drivin' abilities to suit the ride you choose.
Personally (I always do this don't I) I can't get interested in a car that, at speed, doesn't require me to be involved in the process that keeps it outa the roadside scenery. If I could I'd have one of each.
Old 11-18-2005, 06:51 AM   #13 (permalink)
JB
Cheers Matt G
Nice one for the link - question answered
