Old 11-26-2005, 05:17 PM   #1 (permalink)
zorat8
oil change
What is the deal about not changing oil on a new car for the first 7500 miles.I am used to changing oil on a new engins after 1000 miles.
zorat8 is offline   Reply With Quote
Old 11-26-2005, 06:46 PM   #2 (permalink)
CarbonCS
CarbonCS's Avatar
Send a message via AIM to CarbonCS Send a message via Yahoo to CarbonCS
No need!
it's a waste with the new engines to to change the oil so early as the chemicals in the engine (that burning smell for the first 100 miles) have mostly burned off. also the engine is fully spun and broken in at the factory in japan. it's probably too late now but if you had checked the label on the door frame at the time of purchase you would have seen the date the car left the factory. this date is usually less that a few weeks making an oil change even less of a priority. unless of course your driving anything but a honda/acura...
CarbonCS is offline   Reply With Quote
Old 11-26-2005, 08:45 PM   #3 (permalink)
zorat8
oil change
Thanks carbon C S.I have a brand new 05.In the past I had an 00 and the story was that Honda used a special oil with additives that properly "honed the metal of the cylinders and pistons in.That supposedly was the raeson for the long oil change interval.
« New | exhaust »
50k miles, my 1st oil change Elusive8S2k Engine Tech / Drivetrain 22 03-07-2008 06:11 PM
Oil Change john Engine Tech / Drivetrain 8 06-29-2007 06:10 PM
Diff oil & tranny oil arprice Engine Tech / Drivetrain 6 01-21-2007 01:10 PM
tune up/ oil change (-n0-) All Other Honda S2000 Related Discussions 2 08-11-2006 02:55 PM
Oil Stick to check oil.... kccane All Other Honda S2000 Related Discussions 1 07-04-2004 08:32 PM
