s2000 EPS in project car
Hello all, I was hoping to get some info from the maters. I hope you guys can help me!
Ok, I am trying to use the EPS system in a project car of mine. I have it all mounted, ready for the wiring. Since I am not using the f20 motor or tranny, I need some help with deciding what to use for the EPS computer inputs. Based on the factory wiring diagram I have, the following are all inputs: 1)B+ constant 2)B+ IG1 3)speedometer signal from gauge assembly 4)tach signal from ECM 5)"EPS load detect" from ECM, speed signal maybe? 6)3 wires for torque sensor From what I have read, the system only uses the torque signal and the speed signal to operate the EPS. With that said, why would they have 2 inputs for the speed, and a tach signal? Which of these am I going to have to simulate? My question is that since I am not using the ECM, speed, and tach signals, is it possible to "fool" the system into working properly? Is there a way to wire it all up so that I can get the powersteering to work without those signals? If I really do need a speed signal, would a 12V with a rheostat to change the voltage simulate it for a specific speed, then just adjust it as I need? Any other ideas to make this thing work would be greatly appreciated. There has to be a way to get this wiring worked out so that I can use it. Thanks guys Ryan |
| car, diagram, drift, engine, eps, f20, good, honda, problem, project, recommendations, s2000, signal, signals, tach |
| other project | HELL_ON_WHEELS | Off-Topic | 39 | 03-22-2007 06:57 PM |
| Is S2000 a good drift car? | DMC_S2000 | All Other Honda S2000 Related Discussions | 32 | 01-13-2007 11:09 AM |
| S2000 a womens car ? | crazy479 | All Other Honda S2000 Related Discussions | 7 | 03-27-2006 08:04 AM |
| S2000 Car Covers? | DavidHutchesonJr | All Other Honda S2000 Related Discussions | 4 | 11-12-2004 07:09 AM |
| is this the new car that will take over the s2000? | wowowox | All Other Honda S2000 Related Discussions | 5 | 10-13-2004 07:22 AM |
