1st gear
Does anyone else hear and or feel a bump when shifting into first after coming to a stop? Is that normal?
yes it is normal but feel like crap .
I don't have that in mine.
If you add a little pressure to the shifter (but not enough to engage the gear) for a quarter to half second before moving the shifter into position, you will avoid the clunk. The little knock you hear/feel occurs when the syncro can't work fast enough to equalize the speed between input and output shafts.
When you come to a stop and put the gearbox into neutral, there still may be a few rotating parts inside. The light pressure and slight delay on your part will avoid the clunking. If you want to hear the syncros at work (and wear them out a bit), let your car coast at about 20 miles per hour in neutral with the clutch IN. VERY slowly try to put the car into first, without actually going all the way and engaging the gear. There will be a bit of resistance as first accompanied with a slight whine that will increase in pitch as you add more pressure. Eventually the whine will subside, the resistance will disapear, and the gear shift will slide into first like butter. Mechanical goodness |
| 50k miles, my 1st oil change | Elusive8S2k | Engine Tech / Drivetrain | 22 | 03-07-2008 06:11 PM |
| finally bought 1st S2k: 2000' w/26k mi; $16.8k; good deal? | checksindamail321 | All Other Honda S2000 Related Discussions | 5 | 01-30-2006 08:56 AM |
| Gear Grind 1st to 2nd at high RPM | Anonymous | All Other Honda S2000 Related Discussions | 12 | 12-19-2005 06:43 AM |
| Little hard to shift from 1st to 2nd gear | sunnyyan | All Other Honda S2000 Related Discussions | 3 | 08-06-2005 06:19 PM |
| 1ST TIME S2K OWNER and from ATL! | S2KRacer | All Other Honda S2000 Related Discussions | 4 | 07-23-2005 08:11 AM |
