Old 06-19-2006, 08:29 AM   #1 (permalink)
lec6213
Door speaker wiring question
Im installing new speakers and assume that I need to run a new line set to the door from my trunk mounted crossovers. There is no way to use the existing lines in place is there? I assume there is stock crossover already in place? And provided I cannot use the existing lines, how do I run the new lines sets!
I have tried to fish thru the body-door conduit and to no luck. I hope there is a easy way to do this, but I'm doubtful.
Also the new feed is 150 rms to each door, if the stock lines can be used, with regards to wire guage, do i need torun new lines anyways.
Thanks
lec6213 is offline   Reply With Quote
Hard-wiring Radar Detectors? oldboyroy All Other Honda S2000 Related Discussions 1 12-06-2005 11:39 AM
Headrest Speaker System for 2003? baird123 All Other Honda S2000 Related Discussions 0 04-02-2005 09:04 AM
looking for some speaker install help smalls777 All Other Honda S2000 Related Discussions 1 02-23-2005 08:04 AM
yr 2000 speaker wireing sabronson All Other Honda S2000 Related Discussions 4 01-11-2004 11:56 AM
Rear speaker assembly? VA_S2000 All Other Honda S2000 Related Discussions 5 11-05-2003 10:37 AM
