Old 10-17-2006, 04:24 AM   #1 (permalink)
S2KsRGR8
Which oil? Please Help
Hi guys, Got my S2K a couple of months back and it's now time for an oil change. I do all maintenance on this car myself. I wanted to see if there was any Honda preferred oil brand to use or some brand Stewie likes more than another. I already picked up a Honda filter, just need to know which oil and weight to use. Thanks guys.
S2KsRGR8 is offline   Reply With Quote
Old 10-17-2006, 04:36 AM   #2 (permalink)
Lots''a threads on the topic S2. You could start a small riot when it comes to personal preferences, but a safe bottom line is a good name-brand of the weight that mother Honda recommends'll get'cha through no problem.
Though you'll hear some tell ya that only Honda oil, poured while wearin' Honda work gloves n' torquin' the oil filler cap with a Honda torque wrench is the only way to go . . Stewie really isn't all that marque conscious.
Common sense stuff'll get'cha through.
Be well, n' like the old knight said . . .
Old 10-17-2006, 07:47 AM   #3 (permalink)
karnito
karnito's Avatar
I have been using Mobil synthetic oil w10-30. Other then that just follow the Honda's recomendation or look up those thread.
Old 10-17-2006, 07:49 AM   #4 (permalink)
^I use the same stuff.
Old 10-17-2006, 09:37 PM   #5 (permalink)
rukawa1one
rukawa1one's Avatar
yup mobil 1
rukawa1one is offline   Reply With Quote
Old 11-06-2006, 12:49 PM   #6 (permalink)
Excelsis999
Send a message via MSN to Excelsis999
That's right...Full synthetic Mobil1 all the way !!!! Just changed my oil 3 day ago
0W 40
Kinda costs a bit, but it's worth it. My S2000 now purrs nicely
P.S : buy 5 litres, not 4
4 is not enough
Excelsis999 is offline   Reply With Quote
Old 11-06-2006, 01:35 PM   #7 (permalink)
chemical
chemical's Avatar
um you might think im crzy but i put 20 50wt full synthectic just becasue i have a really heavy foot and my mechanic said it would prevent from my engine wearing out as fast and also they say its for hi reving engines too but one thing you have to let it warm up for like 5 minutes cuz it takes a while for the oil to rise
Old 11-11-2006, 04:08 PM   #8 (permalink)
greg
Mobile One Synthetic Blend 10W30
greg is offline   Reply With Quote
Old 11-12-2006, 06:38 AM   #9 (permalink)
Bubblerboy64
I've been told that most engine wear comes from start up before the oil gets circulated. Using a heavier viscosity oil then is recommended is not likely going to help in high speed driving and may actually work against what you are trying to prevent (engine wear). I would use the viscosity suggested by the engineers that built the engine. Mobile one in the correct viscosity for the car will certainly protect the engine at any speed why would you take a chance and go against the manual? John H
Old 11-12-2006, 07:38 AM   #10 (permalink)
jay2000
jay2000's Avatar
I use amsoil series 2000 0-30. It is a great oil, they also make a 10-30.
mods:
K&N Fipk
supersprint exhaust
CR rims
voo doo shift knob
alpine head unit, mb quart qsd 216, jl 300/2.
jay2000 is offline   Reply With Quote
Old 11-12-2006, 10:01 AM   #11 (permalink)
karnito
karnito's Avatar
Higher viscosity is thicker then the lower viscosity. Lower viscosity is ideal for a newer engine with tigher tolerant. Higher viscosity is ideal for older engine with lower tolerant, it is also ideal for a hotter climate like Texas or turbo engine because it has a higher boiling point then the lower viscosity. Nevertheless; I am using Mobile one 10-30 synthetic
[00 GReddy S2K] [03 MB E320] [06 Porsche Carrera]
Old 11-13-2006, 01:37 PM   #12 (permalink)
greg
I just took my Roadster to Honda for an oil change and that is what they recommend.
Old 11-13-2006, 03:10 PM   #13 (permalink)
import2nr
I was thinking of trying royal purple or that greddy type oil, has anyone tryed these brands?
import2nr is offline   Reply With Quote
Old 11-14-2006, 10:20 AM   #14 (permalink)
Kitikithakis
Just my 2 cents but my neighbor (Who owns a Penzoil Quick lube) uses Castrol GTX 10-30 synth on his '04. I asked him if there was any major differences between the oils and he said not really, its mostly preference and name. He prefers the synth due to the fact that synths break down slower from heat and, in the higher rpm cars, its a must. As for the 10-30/10-40 viscosity he uses the lighter viscosity in winter and the heavier in summer. (We're in Dallas). I thought it was a riot that he works for a Penzoil company and uses Castrol though....lol
Kitikithakis is offline   Reply With Quote
Old 09-19-2007, 06:43 PM   #15 (permalink)
dadatwork
Which Oil?
I asked my Houston Honda dealer to put in synthetic at the first oil change (5,500 miles or so). He put in 5W-20 synthetic - don't know the brand. Anybody ever heard of using 5W-20??
dadatwork is offline   Reply With Quote
Old 09-21-2007, 11:09 PM   #16 (permalink)
wallc777
Ok... I have used Mobile 1 synthetic 10w-30 on my 2002 spa yellow, and the damn thing burns oil when revved high.
I called the honda dealer up, and they said that the Honda racing team NEVER uses synthetic on the S2k's... especially in heat, it turns to water.
So... just use regular oil!
Old 09-22-2007, 08:09 AM   #17 (permalink)
Vezna31
Vezna31's Avatar
The one problem I have with that statement is that heat will sludge regular oil MUCH FASTER than synthetic. So, it may thin out synthetic, but you're better off than with sludge. You should go with a higher viscosity instead of regular oil.
Also, most S2000's are known to burn oil.
BTW...I use Mobil 1 10w-30.
Old 09-22-2007, 02:56 PM   #18 (permalink)
wallc777
Vezna, it burns oil... Plus, i can hear the valves when im driving inside the car. Do you hear it too while using 10w-30 mobil 1 synthetic?
Old 09-22-2007, 10:31 PM   #19 (permalink)
I have used Mobil1 10W30 since 10,000 miles (now at 32,000) and have never heard my valves or ever burned a drop of oil. I feel it depends on how the engine was broken in as to whether it burns oil or not.
As for hearing your valves, I would be concerned if I was you and would go have them adjusted.
Old 10-11-2007, 12:27 AM   #20 (permalink)
dr. feinstone
that is a word of wisdom
dr. feinstone is offline   Reply With Quote
Old 10-11-2007, 12:35 AM   #21 (permalink)
dr. feinstone
I have a 2005 gpw and I spare no expenses when it comes to my baby/collection. The first thing to do is read the owner manual. Honda said to use 10w30 gasoline energy saver motor oil. If money is not a constriction in your wallet then spend some extra dollars on synthetic motor oil. Mobil 1, Castrol, Quakerstate, Pennzoil and Royal Purple are ok. ALL ARE RESPECTABLE MANUFACTURES. I use Royal purple 10w30 for engine and 75w90 Max gear for differential with possitive result and increase performance.
Diff oil & tranny oil arprice Engine Tech / Drivetrain 6 01-21-2007 02:10 PM
Need help with oil HELL_ON_WHEELS All Other Honda S2000 Related Discussions 2 04-17-2006 09:27 PM
oil changes silverstone05 All Other Honda S2000 Related Discussions 15 02-01-2006 04:55 AM
Oil Stick to check oil.... kccane All Other Honda S2000 Related Discussions 1 07-04-2004 09:32 PM
Oil Anonymous All Other Honda S2000 Related Discussions 5 12-02-2003 10:04 PM
