Old 11-26-2006, 02:08 PM   #1 (permalink)
Kick it down a gear
Weird knocking noise
I have had my car for a couple of months now, and i absolutely love it. For awhile now though I have heard a sound coming mostly from the passenger side. It sounds like its coming from down in the power top mechanism. Somewhere mid seat level behind the plastic covering. It kinda sounds like a hinged metal arm hitting something else metal. It happens mostly during longitudinal speed changes. I will check the axel nuts, but i dont think its them. Any help will be appreciated.
Kick it down a gear is offline   Reply With Quote
Old 11-26-2006, 03:49 PM   #2 (permalink)
Do you have a test pipe?
Old 11-26-2006, 09:18 PM   #3 (permalink)
Kick it down a gear
no my car is completely stock, I bought it used but it is in great condition and i can tell it wasnt abused and well taken care of.
Old 11-27-2006, 05:53 AM   #4 (permalink)
Not sure, sorry. I thought maybe the test pipe/ cat was hitting the heat shield underneath, but if it is stock, I doubt the cat- exhaust would have shifted and be hitting the shield.
Old 11-27-2006, 11:34 AM   #5 (permalink)
Halo
Halo's Avatar
Metal on metal noise? I'll assume yes.
Any chance it wasn't stock for a while but was converted back before sale?
I'd take a look at the bolts that hold the rear A arms to the body. One, to check they're tight and two to see if they've been wrenched on. They should look absolutely pristine without a scratch if the suspension was not previously modified with springs or coilovers and then returned to stock.
The next thing I'd check are the various hangers for the exhaust.
Without hearing it, those would be the first things I'd check. What you're describing isn't a 'known' problem with the car.
Old 11-28-2006, 07:44 PM   #6 (permalink)
Kick it down a gear
I checked out everything in the suspension and exhaust I couldnt find anything loose at all. Everything looked exactly the way it should.
Thanks for all the help I will keep looking and see what I come up with.
Rattling noise jray8 Engine Tech / Drivetrain 7 07-10-2008 11:02 PM
Wierd noise Dr. Jimbo Engine Tech / Drivetrain 9 06-13-2007 07:44 PM
Weird comparo - Murano v S2000 S2000dude News & Special Announcements 0 01-10-2007 05:50 PM
HELP...WEIRD SOUND COMING FROM EXHAUST!! 01s2kgirl All Other Honda S2000 Related Discussions 3 10-28-2005 07:01 PM
Weird Noises Below Idle... wangdoom All Other Honda S2000 Related Discussions 4 08-05-2005 05:08 PM
