Old 01-06-2004, 10:14 PM   #1 (permalink)
spdracr929
spdracr929's Avatar
Rough Tranny?
My 2004 shifts kinda rough from 1st to 2nd gear just right after a cold start and only during that first shift. Then its pretty smooth after that.
Is anyone else having this problem wit the 2004's or previous models. Its not grinding or anything but it does require more effort. Is this something that I should be worried about? Kinda hard to show the service department this problem since it only happens during the first shift of a cold start.
I will stop making vroom vroom noises at work.
spdracr929 is offline   Reply With Quote
Old 01-07-2004, 10:13 AM   #2 (permalink)
s2k4ntp
s2k4ntp's Avatar
Re: Rough Tranny?
I think it's pretty normal. Most manuals require more effort when it's quite cold outside. My S2000 has similar findings, but it also grind a little from 2nd to 3rd when cold. Once warm, everything works fine.
'02 Sebring Silver/Red interior
'99 Civic EX Coupe 5spd
s2k4ntp is offline   Reply With Quote
Old 01-07-2004, 04:23 PM   #3 (permalink)
Evoxlution637
Send a message via AIM to Evoxlution637
i had the same problem but i talked to the service deparment and they said it's normal.... he said it also could be the driver and how you step on the clutch....
Evoxlution637 is offline   Reply With Quote
Old 01-08-2004, 09:50 PM   #4 (permalink)
spdracr929
spdracr929's Avatar
Not that you mentioned it, mines does grinds a lil bit goin to 3rd also.
honda, rough, s2000, shift, shifter, shifting, tranny
Rough Shifting Jbeni96 News & Special Announcements 7 07-25-2007 08:03 PM
Engine oil & Tranny fluid cpiercecf Engine Tech / Drivetrain 11 04-27-2007 09:26 AM
Growl In Tranny stewie69 Engine Tech / Drivetrain 4 01-16-2007 06:59 PM
Moby 1 in my tranny and diff ok? Tyraid2K All Other Honda S2000 Related Discussions 1 05-30-2005 03:54 PM
