Old 03-23-2007, 06:25 PM   #1 (permalink)
playboymonk
Maintenance reminder for 2006 s2k
When should I get my first oil change for my car? I've been driving it for almost 3 months, and put about 2700 miles on it. Is it true the first oil that is in hondas are special oil that helps to clean out and break in your engine, so you can drive for actually 5/6 thousand miles with it? I have a 2006 S2k, and I heard there is an oil/maintenance gage that tells me when i need to change my oil. Where is it?
Old 03-23-2007, 07:33 PM   #2 (permalink)
Change it when the 'oil life' guage tells you too.
Old 03-23-2007, 08:44 PM   #3 (permalink)
Scott
Scott's Avatar
The light you have heard about is the Maintenance light. I'm not sure about how it is on the AP2, but on the AP1, it's a small yellow light next to the Check Engine and Cruise Control lights along the bottom of the cluster that reads "Maint Req'd".
From the time it is reset, it basically counts down to the next recommended "maintenance", such as an oil change.
1966 Ford Mustang
2003 Land Rover Freelander
Old 03-23-2007, 10:01 PM   #4 (permalink)
The '06 and '07's have a 'oil life' guage that tells the driver how much life thier oil has left. When it say's "0", it's time to change the oil. At least that's the way I understand it.
Old 03-24-2007, 04:23 PM   #5 (permalink)
bladerunner
bladerunner's Avatar
To access it you push the trip button on the bottom right of the dash display. It will cycle through your different trip readings until you reach your oil life which is read in a %. I was told to change it when it reaches 15%, I've never let it get past 50%, but I'm crazy.
Old 03-25-2007, 10:07 AM   #6 (permalink)
BabyItsaFact
Questionable Standing
BabyItsaFact's Avatar
The oil in your engine is a special blend with "breakin" additives. You shouldn't change it until your gauge reads 15% or lower. I don't know why, but that's what Honda says, and they designed the thing.
On a side note, the oil life gauge isn't just a mile counter, it takes into account hours ran, RPMs etc. So you can probably trust it. . . but I dont think anyone would tell you that changing your oil more often (other than the first time) is a bad thing. Fresh oil just works better. It's cleaner. It's slicker. Gosh darn it, it's just OILIER!
BabyItsaFact is offline   Reply With Quote
Old 03-31-2007, 08:04 PM   #7 (permalink)
leo520
guys i got a 2007 i found where i can check all the oils by opened up the hood... but the transmission oil stick is gone....
Old 04-01-2007, 12:01 AM   #8 (permalink)
The transmission on a stick shift vehicle doesn't have a dipstick. You need to pull the plug underneath and put your finger inside to check your levels.
Debate 2006 s2k or Si 2006 IP_Andrey]RUS[ Off-Topic 15 12-16-2006 09:20 PM
2006 S2K prices mtpr1 All Other Honda S2000 Related Discussions 6 06-11-2006 06:05 PM
2006 S2k TC/VSC? Sips All Other Honda S2000 Related Discussions 3 05-24-2006 12:11 AM
2006 S2K UGA Dawg All Other Honda S2000 Related Discussions 10 09-01-2005 02:12 PM
Maintenance Light On- 2000 S2K bg All Other Honda S2000 Related Discussions 1 04-08-2004 11:13 PM
