Old 04-26-2007, 09:10 PM   #1 (permalink)
SPF=0
Headlight aining question
Hi, guys 'n gals -
The cutoff line on my low beams is higher on the passenger side (about an inch at 10 feet), but the center of the high beam spot is higher on the driver's side (about 4 inches at 10 feet). There's only one adjuster. The H-1s are the same brand and they're seated OK. Is this the way everyone's lights are??
Thanx!
SPF=0 is offline   Reply With Quote
Old 04-26-2007, 09:45 PM   #2 (permalink)
spa01s2k
spa01s2k's Avatar
This is the way the low beam headlights are supposed to be. They are that way so the driver headlight doesn't blind on coming traffic. Not sure about your high beams?
2001 Honda S2000
1991 Honda Prelude
1994 Ford Bronco
Old 04-26-2007, 11:40 PM   #3 (permalink)
SPF=0
Yeah, I'm OK with the lows - it's the highs I'm wondering about. Seems like they should both be pointing in the same direction.
Old 04-27-2007, 08:49 PM   #4 (permalink)
leo520
i will like to figure the way out to make my 2007 s2k aim little bid higher...
but just don't know how???
anyone know??
Old 04-27-2007, 09:26 PM   #5 (permalink)
SPF=0
There's a knurled knob in there about the size of a nickel. Use a phillips screwdriver to turn it.
Old 04-28-2007, 10:33 AM   #6 (permalink)
Scooterboy
The headlight are aimed that way from the factory. It does take some getting use to but they work good right where they are at. If you aim them higher you will be blinding oncoming cars. I urge you not to adjust them.
If you do adjust them be prepared to be flashed with high beams from other cars and possibly being pulled over for improperly aimed light (there are laws on the books in many states).
As for the high beams, mine light up the world. There is no cutoff. There are fantastic!
Scooterboy is offline   Reply With Quote
Old 04-30-2007, 11:14 PM   #7 (permalink)
leo520
yeah there is some laws like u just said.but where i in NYC lots of people even got thier hight beam on while they were on the road and lot's of people aim so god damn hight, it even hurts my eye when i pass by then...
and here in NYC never got pulled over because of the Lights ...it never happens b4..
Headlight fix please! Tyraid2K All Other Honda S2000 Related Discussions 0 04-21-2005 06:24 PM
Headlight Aiming - How? tomcat All Other Honda S2000 Related Discussions 1 08-31-2004 07:09 PM
