Posts: n/a
question regarding the s2000 motor (f20/f22)
first off i dont even have an s2000...ive driven them plenty of times and crashed 4 of them while working for honda.
anyways...i have a 2002 accord coupe with the 4 cylinder engine. engine code is F23. the s2000 motor is the f20/f22. are they the same family of engines? the f-series? is it possible to bolt a f20/f22 head to a f23 block? that would make an awesome motor. you would have the low end torque of the accord and the high end hp of the s2000. any clarification of the motors would be appreciated! thanks! |
I doubt that simply botling the head of the s2000 onto an accord motor will get those results. The top end HP of the s2000 is all between 6000 and 9000 rpm. I doubt the design of the accord bottom end would allow you to rev the motor to this degree.
M@ |
Posts: n/a
I don't kow if they it would work, if it would you are correct it would give you great torque on bottom with strong top end hp. Due to the vtec head. I have been reading about civic guys doing this with B series engines. ex. B20 block with a B16 vtec head. this could be interesting if the head will bolt up the that block.
Posts: n/a
willl most likely not work due to the fact the diff displacment
#5 (permalink) | |
Different pistons, sleeves, connecting rods... long list. The very nature of the F20c is designed to have a flat (albeit fairly low) torque curve but extending over a very long rpm range (very motorcycle like). In order for the 'bottom end' to achieve the piston speeds needed to hit 8900rpm, it needs to have the composite reinforcement of the F20c.
#7 (permalink) | |
Re: question regarding the s2000 motor (f20/f22)
Call Jessy @ Monster Garage. He will put it for you. Get me the Chain saw. |
| w.t.b s2000 oil pan 2.0 motor | kakikayleen | Want to Buy/Trade For | 2 | 08-01-2007 07:09 AM |
| can you put a F24 motor in F20 ??? | davehonda76 | Engine Tech / Drivetrain | 8 | 03-07-2007 04:34 PM |
| F20 or F22C | playboymonk | Engine Tech / Drivetrain | 19 | 03-03-2007 08:42 PM |
| S2000 N/S Electric window motor, switch etc | SIX LD | Want to Buy/Trade For | 0 | 02-02-2006 01:00 PM |
| S2000 motor ?? | smacke | All Other Honda S2000 Related Discussions | 1 | 12-15-2003 09:24 AM |
