Old 03-12-2004, 06:10 AM   #1 (permalink)
bigpitbull
Send a message via Yahoo to bigpitbull
Differential Change??
I have been seeing alot of people talk about changing there differential to 4.77 or 4.44 gears. What does every recommend is the better gear and is there anything I need to consider to change on my stock 2000 before changing the gears?
bigpitbull is offline   Reply With Quote
Old 03-14-2004, 05:17 PM   #2 (permalink)
revhi
revhi's Avatar
gears
i have the 4.44 gears now and I think there perfect. From what I'm hearing now, A lot of people are using the 4.77s. I personally feel they are a little to aggressive for regular driving. I think the car would be reving to high at cruising speeds. They also have a 4.57 gear out now.
revhi is offline   Reply With Quote
Old 03-18-2004, 09:49 AM   #3 (permalink)
bigpitbull
Thats cool. How much was the change to 4.44 gears and how big of an improvement was it from stock?
Old 03-18-2004, 05:50 PM   #4 (permalink)
MattG
You will also need something along the lines of a "yellowbox" so that your speed will be indicated correctly after you change the gearing.
eg
http://www.ricks2k.com/products/yellowbox.php
M@
Old 03-18-2004, 08:47 PM   #5 (permalink)
revhi
revhi's Avatar
rear gears
I work at an Acura dealer and am friends with one of the technicians. He did it for me cheap. I think I gave him 100 dollars for it. I hear it should really cost anywhere from 400 to 700 dollars depending on how much people charge per hour.
He actually did it twice because the first time I thought I heard some whistling noises coming form the rear. He took them out and realigned them. Still same noise so I guess it was normal.
Comptech S/C with Aftercooler and tons of other mods
