Old 05-25-2004, 01:27 PM   #1 (permalink)
yulook
Questions about S2000
Hello
This is going to be a stupid question but has anyone removed the stock air box and left the air filter opened? Is this a bad thing?
yulook is offline   Reply With Quote
Old 05-27-2004, 09:18 AM   #2 (permalink)
joegrind
its not a good idea to run the car with no filter,but whan u can do is take the stock out the box and replace with a k&n type.
joegrind is offline   Reply With Quote
Old 05-28-2004, 02:21 PM   #3 (permalink)
naynay
Send a message via AIM to naynay Send a message via MSN to naynay
If I understand correctly, you want to still run the filter, but just take off the cover. If this is the case, it wont hurt anything, will make your intake alot loader and you will also loose HP. Not enough to notice though.
naynay is offline   Reply With Quote
Old 05-30-2004, 11:20 AM   #4 (permalink)
yulook
That is correct. I'm going to leave the filter there since the factory seems to be the K&N. I wanted to know if it would hurt or be bad by taking the box. Why would you lose hp?
Mark
Old 06-03-2004, 01:18 PM   #5 (permalink)
ahbongkadah
You will loose HP due to heat soak. ur much better off keeping it on, also dyno tests have proven that the stock filter makes more hp than the k&n anyways, plus the k&n lets in more crap. there is a mod you can do to the stock air box, that requires covering that little hole it has in the back, which would make it sound a lot better and wouldn't hurt performance. If you do a search on s2ki there is a write up with pics... good luck
ahbongkadah is offline   Reply With Quote
More Questions cpiercecf Engine Tech / Drivetrain 3 04-29-2007 08:34 PM
Questions about what comes with a new S2000 lazyasian Off-Topic 4 07-25-2005 07:47 AM
Questions concering Apexi VAFC2 and 05 S2000 S2k05 All Other Honda S2000 Related Discussions 1 07-20-2005 08:38 AM
QUESTIONs DiegosHondaS2000 All Other Honda S2000 Related Discussions 4 07-09-2005 08:56 PM
Serious Questions for a Honda S2000 Wanna-be-driver Anonymous All Other Honda S2000 Related Discussions 5 10-20-2003 03:01 AM
