18 inch wheels with 38 offset fit a 02 s2k????
I have 18" Work Meister S2r's. They are 8" wide front and 9" wide rear. The offsets are +51 fnt. and + 63 rear. I think if you don't get a higher offset than +38, it may look a bit funny. Oh, mine is an '03.
what are you trying to do, get the spoon brake???
well if you do go for the 16, 18 might look better, but you'll find out that 16 is faster been there ,done that ,seee it
They said is the V8 that should fear but its the VTEC doing all the smoking here |
HELP PLZZZ
can n e 1 plz explain what the offsets mean becuz i do no understand....
#5 (permalink) | |
S2000 Member
http://www.tirerack.com/wheels/tech/...jsp?techid=101 http://www.yokohamatire.com/utcustom.asp Here's one that might be of use for future reference: http://www.familycar.com/alignment.htm#Scrub%20Radius ... |
S2000 Member
I would say no according to the info below unless you run very skinny tires...
This has been posted in other threads on another s2000 forum by some sharp guys who have had a lot of experience compiling data on tires and wheel offsets for "real world" s2000 applications - not those who just sell tires and wheels: Based on successes and failures from many S2000 owners, we can use an offset calculator to figure out what other offsets and tires will work. These are minimum recommended offsets. You can use a higher offset if you want, and you will get additional fender clearance. For the front: 6.5” to 7.5” wide wheel: 205 tires: +43 offset minimum 7.0” to 8.0” wide wheel: 215 tires: +48 offset minimum 7.0” to 8.0” wide wheel: 225 tires: +53 offset minimum 7.5” to 8.5” wide wheel: 235 tires: +58 offset minimum 7.5” to 8.5” wide wheel: 245 tires: +63 offset minimum For the rear: 7.5” to 8.5” wide wheel: 235 tires: +40 offset minimum 7.5” to 9.0” wide wheel: 245 tires: +45 offset minimum 8.0” to 9.5” wide wheel: 255 tires: +50 offset minimum 8.5” to 9.5” wide wheel: 265 tires: +55 offset minimum 9.0” to 10.0” wide wheel: 275 tires: +60 offset minimum 9.0” to 10.0” wide wheel: 285 tires: +65 offset minimum |
Good work Sid. Bumpety bump bump.
Um-m-m-m . . . guyz, we doo realize that we're respondin' to a post workin' on 4 years old? Right?
#10 (permalink) | |
That's hilarious. Good job el sid that guy has been waiting 4 years for an anwser to that quetion.
GO FAST OR GO HOME
| Upgrading wheels, what size/offset? | Elusive8S2k | Wheels / Tires / Suspension | 12 | 01-20-2007 11:02 AM |
| what wheels fit are best? | scottyl9 | All Other Honda S2000 Related Discussions | 0 | 10-18-2005 10:44 AM |
| Will these wheels fit? | Luckyace | All Other Honda S2000 Related Discussions | 0 | 03-14-2005 10:01 PM |
| 19 inch wheels | S2KJakarta | All Other Honda S2000 Related Discussions | 0 | 08-10-2004 02:00 PM |
| WANTED:rims that have perfect offset for s2000 18-19 inch | twofast4u | Want to Buy/Trade For | 4 | 07-11-2004 06:52 PM |
