15k maintenance question
i just hit 14k on ap2. i need to get 15k maintenance soon. i dont have tools or skills or garage to it myself. so i am going to take it to the dealer. do i just tell them i need 15k maintenance?
give me some tips on specifics. also should i get transmission oil changed as well? thanks
94 Toyota Corolla Maroon 02 Mercedes Benz C230 Sport Coupe Black 04 Land Rover Freelander White 06 Honda S2000 Silver |
Having the maintenance reminder it should say A or B service when you have reached the required milage. If it does'nt the garage tecks will know.
Neil |
#3 (permalink) | |
2007 berlina black |
What year AP2 again?
If you have the maintenance minder (06+) then the tranny fluid isn't due until it shows "3" on the display. Otherwise it depends on whether you are in an area that is normal or severe conditions. I would recommend every 2yrs/30,000 miles on trans fluid. Otherwise to answer your original question: ![]() Last edited by Boost Convert : 02-11-2008 at 05:53 PM. |
thanks. i dont have the manual
800-782-4356
helm helminc.com Oh, and if it's an 06 then you have the Maintenance Minder, so just drive it to 15% oil life and see what codes come up, service is due at 5% oil life. Don't get a dealership try to sell you more than you need. Honda designed the system to work with the vehicle, trust it. ![]() Last edited by Boost Convert : 02-12-2008 at 07:20 AM. |
#7 (permalink) | |
and don't ever rotate the tires on a Honda S2000. if you do, bad things will happen. guaranteed. spark plugs are a 100,000 mile item. so is coolant. my opine is that they need to be changed before that mileage, but that is what honda says. maintenance minder is a great thing---but use your common sense as well.
#8 (permalink) | |
Trqless
Of course we all know not to rotate the STOCK tires. But the wheels I just ordered are same width all around, (I wanted staggered, but owell), so IF THEY CAN BE ROTATED, do it. Obviously, we all know if they can't...
![]() Race time. Got to be serious, not stylish. ![]() www.myspace.com/kesmith3 |
#9 (permalink) | |
changing oil without a filter change--waste of time, money and oil. sorry ma. better than nothing though. most of the tires you are going to put on an s2000 are one direction only. that means back to front / front to back rotation only--and then on non-staggered, non-stock tires. and non-staggered wheels on an s2000 seriously affect handling--you are not trusting ma on this one. and i suggest that you do rotate them. and watch your ass. because it is going to be breaking loose...oh, well. don't know if we all know about tire rotation. a lot of the questions from these inquiring minds gives rise to the fact that a lot of these folks don't know a lot about maintaining a car. and there is a lot that is specific to the s2000 that does not apply to other vehicles. you know not to use your factory equipped spare on the rear, don't you? i'll bet a lot of folks out there don't know that one. of course, this is just my opinion.
You're right, the tire rotation is simply part of the maintenance minder system and is not to be done on the S2K. You CAN perform the "A" service and be just fine, but I know 95% of dealerships here in Phoenix add changing the filter to the "A" service (our dealership) included.
bad advice is worse than no advice. i'm through here.
