Old 02-15-2008, 09:41 AM   #1 (permalink)
oks2000
oks2000's Avatar
How to adjust headlight?
I think it needs to be adjusted! How do i do this thanks ?
oks2000 is offline   Reply With Quote
Old 02-15-2008, 09:59 AM   #2 (permalink)
Neil
Neil's Avatar
In the book it says that it should be done by a dealer or mechanic, but there has to be adjustment screws for re-alignment
Good luck Neil
Old 02-15-2008, 11:03 AM   #3 (permalink)
oks2000
oks2000's Avatar
Good luck Neil
Thanks Neil that is what i was reading. Im thinking the headlight has to come out! That sucks for me of that is the case.
Old 02-15-2008, 11:25 AM   #4 (permalink)
Unless you have been in a crsh you probably don't need to adjust them.
Old 02-15-2008, 11:48 AM   #5 (permalink)
oks2000
oks2000's Avatar
I guess im not use to how low the car sits. I drove a big powerstroke for a long time so i feel like im sitting on the ground and so does the lights.
Old 02-15-2008, 12:42 PM   #6 (permalink)
Neil
Neil's Avatar
Are they both in alignment, or is it that just one needs adjustment. Make sure there's no heavy goods in the boot.
Neil
Old 02-15-2008, 02:27 PM   #7 (permalink)
oks2000
oks2000's Avatar
Neil
it looks like my driver side is kinda down from a distant but on a wall it looks to be the same.
Old 02-15-2008, 04:59 PM   #8 (permalink)
Neil
Neil's Avatar
Run it over to your nearest Honda dealer for A QUOTE ONLY.
Question the tech when he looks at it, maybe theyll giv ya some idea on how to fix.
Old 02-15-2008, 09:24 PM   #9 (permalink)
Scooter
Senior Newbie
Scooter's Avatar
That's normal, the drivers' is a little lower to be nice to oncoming traffic. Wierded me out for a while until I learned that here...
Old 02-15-2008, 09:33 PM   #10 (permalink)
philiam
What's up with the high beams? Are they just for flashing?
Old 02-17-2008, 10:08 PM   #11 (permalink)
oks2000
oks2000's Avatar
Ok that is what i was told as well!
