Old 03-03-2008, 04:46 PM   #1 (permalink)
cleargrip
wtf
i thought the s2000 had xenons of hids or whatever their called now people are telling me they dont
cleargrip is offline   Reply With Quote
Old 03-03-2008, 05:27 PM   #2 (permalink)
tuna79
tuna79's Avatar
They do, and they're fantastic. The color is determined by the temp they burn at measured in kelvin. 4-6k are the best for brightness and visibility. The hotter they get the more colorful. Mine are 12k and are very illegally blue but damn cool so I'm not changin till the fuzz starts chasin me down.
tuna79 is offline   Reply With Quote
Old 03-03-2008, 05:35 PM   #3 (permalink)
SilverS2K422
SilverS2K
SilverS2K422's Avatar
how do you get 12k?
Old 03-03-2008, 05:46 PM   #4 (permalink)
cleargrip
yeah is it just a bulb or something or do you have to get a conversion
Old 03-03-2008, 06:53 PM   #5 (permalink)
You take 11k n' add one. (Sorry Sil. 'Couldn't help myself.)
Old 03-03-2008, 07:16 PM   #6 (permalink)
SilverS2K422
SilverS2K
ha ha
Old 03-03-2008, 07:48 PM   #7 (permalink)
As already stated, the S2000 has HID lights.
Old 04-09-2008, 08:04 PM   #8 (permalink)
kaotik25
you can keep the existing ballast and harness just need to get the D2S bulbs with 12000K rating. you can find these anywhere. Hope that helps.
kaotik25 is offline   Reply With Quote
Old 04-09-2008, 08:18 PM   #9 (permalink)
sonic
sonic's Avatar
How much do they run? Are they hard to install?
GO FAST OR GO HOME
Old 04-10-2008, 08:09 AM   #10 (permalink)
ap1sleeper
they are not hard to install. The only way I know to change the low and high beam bulbs is to remove the headlight from the car. Once that is done it is a REALLY simple process. I am not sure, but you MAY be able to go in from the engine bay just behind the headlight on the fender to reach the low beam HID....dont hold me to that though.
ap1sleeper is offline   Reply With Quote
Old 04-11-2008, 12:24 AM   #11 (permalink)
Wheazel
On my European version the lights come with a polyellipsodial lens xenon for low beam. The high beam lamp is a regular H1. Just days ago I did convert those H1s into 6k xenons. Had to weld custom holders, will take a pic hopefully during weekend.
Oh and the high beams are the ones closest to the engine compartment so the access holes should be enough to get there. Its a narrow place tho and I did my install now that my car is disassembled for upcoming turbo installation. Makes things easier. Hardest part of installing the xenons was to get them into the custom holders and insert them without touching the glass and pollute the surface. (Shortens lifespan significantly)
/Wheaz
Wheazel is offline   Reply With Quote
Old 04-11-2008, 08:05 AM   #12 (permalink)
Pablo
Sentient Being
Pablo's Avatar
High beams for sure can be changed from the engine compartment. I recently changed mine to H1 "cool blue". Look in the manual for instructions. They are not great, but do help.It's not easy however. Small hands are a must, and be careful of sharp edges. The left side is easier than the right so start with the left.
Regards,
Pablo
