Check Engine Light
anyone know how to get rid of the check engine light? (i'm pretty sure it's on b/c of the gas cap not being clicked the magical 3 times) or is this one of those plug the ol computer in thingy's.
I took mine to the dealer when I had the oil changed. It is probably the gas cap. My wife had the car and left it off!
CHECK ENGINE LIGHT
My light came on for about a week which made it idle very uneven.Then decided to have it looked at and guess what ? It went out on its own accord and hasnt been on since,about 1000mls later.
Still dont know what the problem was. |
well i had mine hooked up as it eventually started flashing which i knew was not good and it turned out to be a bad fuel injector. all is well now and my S is faster than before.
Fix for check engine light
Hold down the trip button, turn the key on, keep holding the button til the light goes off.
~Jc |
There is a big difference between the CEL (check engine light) and the service engine light.
While the latter can be reset as posted above, it is merely a reminder that the upcoming recommended service interval (7500mi) is soon. The former means that the onboard diagnosics has noted a problem. Just resetting it (by pulling the fuse or d/c the battery) won't make the problem go away. As an example, if you had single bad injector as described above, you could end up with a single cylinder lean condition that might result in needing a rebuild if that cylinder has detonation. |
| CHECK ENGINE LIGHT KEEPS COMING ON.. | ericthefarmacist | All Other Honda S2000 Related Discussions | 8 | 01-12-2006 12:10 PM |
| Check Engine Light | Bill Karras | All Other Honda S2000 Related Discussions | 2 | 04-28-2005 10:54 AM |
| Check Engine Light coming on around 15k miles, fix inside!!! | Just Cliff | All Other Honda S2000 Related Discussions | 0 | 10-12-2004 02:51 PM |
| engine check light | nosherduke996 | All Other Honda S2000 Related Discussions | 0 | 08-31-2004 01:39 PM |
| odd check engine light | Draven | All Other Honda S2000 Related Discussions | 0 | 07-07-2004 09:01 PM |
