Guest
Posts: n/a
Gear Grind 1st to 2nd at high RPM
Hello -- maybe I'm just used to Mustangs with the tough old top loader transmission, but the new S2000 I picked up today requires a very conservative (meaning somewhat slow) shift from 1st to 2nd to keep from grinding when up over 8000 RPM. The other upshifts don't seem to have this issue.
Are others out there able to do fast (tire squealing) shifts from 1st to 2nd without a problem? This new car had 500 miles on it when I bought it, so someone could have possibly damaged the 1st gear synchro. Other than that issue, I love the car. It's amazing what happens up over 6000 RPM! |
Guest
Posts: n/a
What year is your S2000? There is a known issue with the '00 and '01 transmissions and there is a TSB (technical service bulletin) out that addresses the problem and replaces defective parts. I'd definitely mention the problem to your dealer and ask if your car is a candidate for the TSB fix.
Guest
Posts: n/a
Year
It's a 2003 with only 600 miles on it. -- Thanks
definetly take it to honda and tell them that it grinds but don't say that you take it to above 8,000 or else they will say its abuse. They will give you a new trany and everything will be fine. I've already had mine redone 2 times and you just have to put the clutch in really fast before you switch gears. Try actually banging the clutch to the floor so you hear it hit and then shift fast.
04 Silverstone/Black 89 CRX (For Sale) |
Guest
Posts: n/a
i just recently got an s2000 to. I traded in my ss camero and i also have the same problem. When i shift after 8500rpm the gear grinds but only from 1st-2nd.
Opposite problem
I have the opposite problem. My synchros don't mesh at lower rpms. 5k and higher the gears lock right in, but 4k and lower there's a mild kurchunk when the gears mesh going from 1 to 2, from 2 to 3 and from 3 to 4. It's in the shop right now at a Honda dealer. They tell me that they all drove it, including a Honda rep who just happened to be in town. They say it's perfectly normal for that car. That doesn't sound right to me. Everything I've read about this car, especially '02 and later, is that the transmission is very solid and precise. I would not expect any clicking or clunking as the synchros mesh. And I don't always want to shift at 6,000+ rpms.
me too
i have an 04 and i noticed when i rev 1st all the way out and shift hard to second, i dont grind gears but i hear a sharp click, i know it shouldnt happen, only from 1st to 2nd, it only happens once in a while but its just there in the back of my mind that my tranny might be taking a beating
Well my car grind from 1-2 grind alll the time and there is nothing about it, howver if u really drive carefully the problem is less obivious. for my car i had to either change the gear abit slower than other hears when from 1-2 or i can do it by having the cluth down earlier/faster. by doing this 2 thing the car will be less likely to grind. so u guys think u can actually get a new tranny out of this kind of problem ???? or just the synchro replaced??
thx |
Well, I'm not expecting, or even wanting a new trans for this problem; perhaps mine is not as bad as yours, but if it gets worse, then I'll be looking at having Honda replace the Trans under warrantee. Meanwhile I'm going to bring my S2000 into a different Honda dealership to see if they give me the same diagnosis; ie: "It's totally normal for that car. There's absolutely nothing wrong with it." We'll see...
Check out this link guys
http://www.s2ki.com/forums/index.php?showtopic=330883 |
#11 (permalink) | |
| 2nd, clunk, clutch, gear, grind, grinding, grinds, high, letting, rpm, rpms, s2000, s2kiorg, shift, transmission |
| 2nd Annual Summer BBQ | Vezna31 | San Diego Chapter | 15 | 08-29-2007 10:10 PM |
| Gear grind | john | Engine Tech / Drivetrain | 5 | 08-04-2007 11:47 PM |
| Rpm | MADMAX27330 | Racing Discussions | 14 | 01-20-2007 08:09 PM |
| 1st gear | (-n0-) | All Other Honda S2000 Related Discussions | 4 | 04-07-2006 12:48 PM |
| Little hard to shift from 1st to 2nd gear | sunnyyan | All Other Honda S2000 Related Discussions | 3 | 08-06-2005 07:19 PM |
