some questions for the 00 and the 03 models
I am an owner of a 00 and I would like to make some small modifications, since I have found some used parts from a 03 model. I would like to ask if some parts of the 03 fit to 00,
1. Does the door panels of the 03 (with the tweeters) fit to the 00? 2. Does the top of the 03 (with glass) fit to the 00? 3. Any idea where the water pump for the headlight is? (only european models have headlight washers, I think!) or any other possible/common reason for not working.. I have the service manual but nothing is mentioned about headlights washers!! 4. If I buy a hardtop for a 03 will it fit to the 00 with the proper installation kit or I should get a hardtop for the 00 from the beginning? 5. will the rear lights of the 03 (with the grill) fit to the 00? thats all for now, Greetings to all from sunny Greece! many thanks in advance Nick |
1. yes
2. yes some people have done it already 3. sorry can't help you on that one 4. I think the hardtop is the same for 00 and 03. Maybe you could check this with your dealer. 5. yes |
The top conversion to glass window (02-03) is possible on a 00-01. However, it is not plug and play, some mild modifications are required to the frame (6 holes drilled, 4 straps installed). It also requires rivet removal and riveting.
| would 04-05 tail light fit on 00-03 models? | kyungkp | All Other Honda S2000 Related Discussions | 4 | 02-12-2008 01:49 AM |
| Different Models? | Djthomas1189 | Engine Tech / Drivetrain | 7 | 03-08-2007 01:04 PM |
| Any difference betwee 04 and 05 models | Bob | All Other Honda S2000 Related Discussions | 4 | 10-20-2005 09:08 AM |
| 05 models and vtec | malaguti | All Other Honda S2000 Related Discussions | 27 | 06-10-2005 02:48 PM |
| Informations about all models will be appreciated... | Administrator | Website / Forum Suggestions / Site Problems | 0 | 04-09-2004 09:09 AM |
