Old 10-12-2004, 02:51 PM   #1 (permalink)
Just Cliff
Send a message via ICQ to Just Cliff Send a message via AIM to Just Cliff Send a message via Yahoo to Just Cliff
Check Engine Light coming on around 15k miles, fix inside!!!
Not sure if all of you know about this, and/or know how to fix it, but I found out today and figured I would share. A service consultant was in the dealership I work in today and I asked him about the Maint Required Light, or whatever it says that comes on, I'm well aware that allot of manufacturers have this wonderful little service light that comes on at a certain amount of miles and they get allot of service work out of it. Anywhooo, he told me the 15k mile maint. isn't critical and basically, they change the oil, rotate tires, adjust the calipers and charge you $xxxxx.xx.
Here's the fix.
Hold down the trip button, and then put the key in and turn it to the on position, continue to hold the button, the light will flash, and after a few seconds, go away. he did however metion that the 30k mile service was of greater importance, all the fluids are changed then, as well as some other minor replacements and fixes, all which could be done by you at a lower cost.
Thought I'd share, new to the boards, hope this helps, see you all out on the twisties.
~Jc
Just Cliff is offline   Reply With Quote
CHECK ENGINE LIGHT KEEPS COMING ON.. ericthefarmacist All Other Honda S2000 Related Discussions 8 01-12-2006 12:10 PM
Check Engine Light Bill Karras All Other Honda S2000 Related Discussions 2 04-28-2005 10:54 AM
Check Engine Light gstate All Other Honda S2000 Related Discussions 7 10-15-2004 10:16 AM
engine check light nosherduke996 All Other Honda S2000 Related Discussions 0 08-31-2004 01:39 PM
odd check engine light Draven All Other Honda S2000 Related Discussions 0 07-07-2004 09:01 PM
