Old 02-19-2005, 07:12 PM   #1 (permalink)
wowowox
Tire + rim questions
Hi, after seeing many ppl change their rims and tires i was wondering what u guy ususlly buy ? i mean do ppl usually buy bigger ones which the overl size is bigger than original or ppl simply just use a bigger rim but lower profile tires? and if the overall size changed what do ppl do to fix their speedo meter?
thx
Old 03-02-2005, 03:17 PM   #2 (permalink)
SIIK2NR
You should always buy the same size diameter when possible. When "up-sizing" the overall aspect ratio may change slightly and you will feel it in the gearing due to the larger size and added weight.
If you stay with OEM specs then you will have no problems with the speedo. If you upsize to 18's it will be a little off 4-8 miles per hour depending on the tires you get. If you upsize to 19's it will also be off.
Most people upsize to 17's or 18's and a few go up to 19's.
SIIK2NR is offline   Reply With Quote
**SUITABLE RIM COLOUR FOR A YELLOW S2K???** jason All Other Honda S2000 Related Discussions 6 08-20-2006 11:23 PM
Busted rim dia_cero2002 All Other Honda S2000 Related Discussions 12 12-02-2005 01:56 PM
QUESTIONs DiegosHondaS2000 All Other Honda S2000 Related Discussions 4 07-09-2005 09:56 PM
rim and tires? ChippedS2k All Other Honda S2000 Related Discussions 0 04-30-2004 01:39 PM
questions Anonymous All Other Honda S2000 Related Discussions 0 05-29-2003 10:08 PM
