Old 03-05-2005, 07:36 AM   #1 (permalink)
Just Cliff
Send a message via ICQ to Just Cliff Send a message via AIM to Just Cliff Send a message via Yahoo to Just Cliff
Free Sex, Made You Look, Serious Question Inside!
My car pulls to the left, it's not alignment, or balance, or tire pressure.
The car tracks straight when I let go of the wheel, or at least I think so, and it stops straight when I take my hands off the wheel and apply the brakes, or again, at least I think so.
The pulling happens when I'm acelerating, when I apply the clutch and shift gears, it seems to pull the car and make it wiggle a little, almost like a speed wabble.
I'm not tugging on the steering wheel when I step on the clutch and shift, because again, it happens when my hands are off of the wheel.
I know it's a good idea to drive with hands on the wheel, but I swerve less when I'm driving free ball. Just Kidding. Love my S2K, just wonder if anyone else has had this issue, and if there is a fix other than going to the factory shop and getting it tweaked. It's still under warranty if that matters, and it's an 03 S2k.
Just Cliff is offline   Reply With Quote
Old 03-05-2005, 04:22 PM   #2 (permalink)
dbzerk
Send a message via MSN to dbzerk
have you done any engine mods? could it be an engine mount? or the actual road you are driving on?
dbzerk is offline   Reply With Quote
Old 03-07-2005, 01:11 PM   #3 (permalink)
Just Cliff
I've thought about maybe an engine mount, not really sure. I'll check with some mechanic buddies before I run it through the Honda shop and post my results here .
Old 03-16-2005, 09:56 AM   #4 (permalink)
smalls777
smalls777's Avatar
Send a message via AIM to smalls777
check that the rear upper and lower ball joints are not loose or worn or just damaged. also check rear diff fluid, i know this is a stretch, but if that diff is not working properly it will give another wheel more torque under acceleration and move you to one side. on a front wheel drive car, motor mounts would matter, but on this car it will just be a major vibration. also inside your inner cv (constant velocity) joints there are tiny teeth entering the diff that if get stripped (rare, really rare) can cause one side to slip and one side to grip causing that thing to get loose under hard acceleration. hope it helps...
smalls777 is offline   Reply With Quote
A jacket I had made. gomarlins3 All Other Honda S2000 Related Discussions 9 02-08-2007 10:43 PM
Whistling From Inside ? Estukay Engine Tech / Drivetrain 4 01-17-2007 05:37 AM
Honda S2000 Custom Made Covercraft Weathershield Cover S2000-4SALE Parts For Sale 0 11-26-2006 02:54 PM
Free Sex!!!!! Just Cliff All Other Honda S2000 Related Discussions 3 12-01-2004 02:52 PM
Want a FREE IPOD! Macgyver5 All Other Honda S2000 Related Discussions 0 10-06-2004 12:11 PM
