Old 06-19-2005, 10:03 PM   #1 (permalink)
Without gettin' nuts
If anyone's already done the homework, wouldja mind if I looked over your shoulder? I don't feel like re-inventing the wheel so if anyone's already cracked the books (catalogs) I'd appreciate the benefit of your knowledge. Without adding a supercharger, turbo or nitrous, what's thought to be the best combination of equipment (aftermarket or Honda) to get the most efficient runnin' naturally aspirated S2?
I'm also told that somebody's makin' a carbon fibre hardtop but ain't havin' much luck locatin' 'em.
All help appreciated, thanx muchly.
Old 06-20-2005, 05:28 AM   #2 (permalink)
wowowox
to keep it NA and if u got the $$
1. weight reduction (carbon parts, lighter wheel, remove a/c etc)
2. racing valve and related paerts, cam shaft and perhaps psitons if their is one@@?
3. new clutch, and differencial (two kinds top speeed or response), transmission for more effcient power deliver
4. full exhaust + intake (some intake give u negative hp)
5. ground wire, stablizer, etc....
6 whatever u can think off beside sc or turbo
ps. i think i am the only who might reply to this kind of question ... @@
Old 06-20-2005, 07:08 PM   #3 (permalink)
Ummmm . . I was thinkin' more in terms of fuzzy dice. No. Actually I'm still pretty thrilled with the stock system all around. I'm not lookin' to get into the innards of the engine or anything that elaborate. What I was lookin' for was more like a "brand X exhaust system flows better than the rest of the aftermarket stuff and brand K has a cold-air intake system that gets the most air down the little beast's gullet" . . or somethin' along those lines anyway.
But wowowox, just for playin' n' not to go home empty handed, we've got this really nice set of steak knives for you.
Many thanks, really appreciate your input.
Old 06-21-2005, 03:06 AM   #4 (permalink)
MattG
Weight reduction can be a cheap mod, by simply removing items from the car. Here is an extreme example:
http://forums.vwvortex.com/zerothread?id=776885
The standard dual exhaust is quite heavy. Even with the best aftermarket exhaust you would be struggling to get more than +5 HP. Look for a lightweight single exhaust (eg T1R)
Air intake - most people seem to prefer the AEM v2.
An aftermarket engine management computer (eg AEM EMS, Greddy emanage etc) may give you a slight improvement also, but gains are minimal if you don't have some forced induction.
I wouldn't bother with those "grounding wire" gimmicks.
Old 06-21-2005, 03:14 AM   #5 (permalink)
'Can't thank you guys enough. 'Really do appreciate you sharin' your knowledge.
Old 07-01-2005, 10:32 AM   #6 (permalink)
fletch
fletch's Avatar
JJ. Two words.
Spoon
Mugen
Possibly the best two suppliers of performance parts for the S2000.
Air intake, Exhaust, ECU etc
Changing them will give HP gains but only small ones and the cost is very high.
There's not much juice to be squeezed out of this engine that Honda haven't already got out of it.
I mean 120bhp per litre.
fletch is offline   Reply With Quote
Old 07-01-2005, 11:55 AM   #7 (permalink)
Thanx fletch. I sprang for the denaro to pick up the S2 because I'm not at a point of my life that's allowin' me to hot-rod somethin' to do the job n' the S2 was the closest thing to what I wanted for a ride. I'd've preferred a hardtop, but I seem to be bearin' up under my ride bein' a convertible. (But maybe I should reserve judgement until after a winter. I keep havin' flashbacks to some rather user-unfriendly moments with the combination of nasty winters n' my old Healey)
But I figured that in it's naturally aspirated state it'd be pretty much like the bikes at the track: you can get the same results outa an investment of $750 worth of light-weight, unobtanium replacement parts as you can outa skippin' a few meals. Didn't figure on any surprises. But it never hurts to get a 2nd opinion.
Thanx muchly, and may your days be clear and the twisty road ahead void of all traffic.
Old 07-01-2005, 12:05 PM   #8 (permalink)
fletch
fletch's Avatar
Thank you too sir.
I'm guessing you haven't got the hardtop kit for the S?
It is nice for the winters.
To add it, after market, costs around ?1500 over here, IIRC.
Old 07-04-2005, 11:05 AM   #9 (permalink)
siLLy_g00se
Send a message via AIM to siLLy_g00se
Redo your fuel system. Vtec uses alot of fuel and if you give it more you can gain some power. pump, fpr, injectos and rail. intake, exhaust, cams, and all you other goodies.
siLLy_g00se is offline   Reply With Quote
Old 07-05-2005, 10:14 AM   #10 (permalink)
Halo
Halo's Avatar
Huh? Just adding more fuel will make the mixture richer. Exactly how does that 'gain some power.'?
Old 07-05-2005, 10:56 AM   #11 (permalink)
Well, Halo . . I guess the secret's out. They found out about the factory racin' Diamond Reo injectors used in conjunction with the Rolls-Cunnardly evaporator brackets. The factory's not gonna be pleased.
Old 07-06-2005, 01:01 AM   #12 (permalink)
MattG
Damn I guess I better throw this jet engine out.
Old 07-06-2005, 03:10 AM   #13 (permalink)
tloc
tloc's Avatar
Send a message via AIM to tloc
LOL
tloc is offline   Reply With Quote
Locking wheels nuts P7rns All Other Honda S2000 Related Discussions 0 03-25-2005 08:41 AM
