Guest
Posts: n/a
Catalytic Converter Test Pipe
Hi,
I am a driver of a S2000 in Belgium. Recently I have bought a header and the Catalytic Converter Test Pipe (00-02 S2000) of Comptech. The problem with that pipe is that the engine light continues burn. Is there anybody who has a solution for this problem? In advance thanks for collaboration. Johan. jospi@pandora.be |
Guest
Posts: n/a
you need a O2 sensor simulator, the light comes on because you unplugged that sensor, go to your local performance shop and ask for it.
i hollowed our my car and my light wont go off, my friend has a shop and he plugs that red computer thing into the ecu and it comes up as catylic converter error or something, you can turn off the check engine light but it will come back on after a few days, or hours. i have turned mine off like 3 times, i dont care anymore
Here is a mechanical solution, 100% reversible:
http://www.s2ki.com/forums/index.php...f=133&t=229959 It involves using 'spark plug anti-foulers' to move the O2 sensor a bit out of the path of the exhaust gasses thus diluting the amount of unburned fuel seen by the O2 sensor. Basically, all you're doing is buying two hollow bolts that thread onto the O2 sensor bung, drilling them out so the hole in the middle fits the O2 sensor, and using them as a spacer. The thing to watch out for is that now the O2 sensor is about 5 cm further away from the test pipe. This is no problem if your O2 sensor is pointing up toward the bottom of the car. But, if you have a design where it's pointing to the ground, it might put the sensor too close to the ground and might hit if you go over a speed bump too fast... Here is a pic of my install (click): http://www.s2ki.com/forums/index.php...=si&img=253547 Works like a charm. You'll have to disconnect your battery or reset the ECU in some other way to clear the error code for the CEL. |
| 02, catalytic, catylic, converted, converter, forums, hollow, honda, install, pipe, s2000, sensor, test, testpipe, unplug |
| Test Pipe Suggestions for a 2007? | SRT-4 | Engine Tech / Drivetrain | 3 | 07-06-2007 01:35 PM |
| 70mm test pipe? | bobby2002S2K | Engine Tech / Drivetrain | 0 | 04-16-2007 06:59 PM |
| Lookin for test pipe | soon2be | All Other Honda S2000 Related Discussions | 1 | 07-26-2006 12:53 PM |
| Just test drove a 2006 S2000 | LaunchIT | All Other Honda S2000 Related Discussions | 5 | 01-24-2006 02:57 PM |
| Need dyno test of stock S2000 `00 | Red | All Other Honda S2000 Related Discussions | 1 | 01-10-2004 03:03 AM |
