Old 10-28-2009, 09:20 AM   #1 (permalink)
tuna79
tuna79's Avatar
Prop shaft is stuck
I'm taking off my transmission, all the bolts are out shifters out, driveshafts off. The trans slid about an inch off of the bell housing but now won't budge. it spins freely and has plenty of room to come off it's just bunged up on something. Has anyone had issues with the shaft getting stuck in the bearing or am I missing something?
tuna79 is offline   Reply With Quote
Old 10-28-2009, 10:41 AM   #2 (permalink)
Dr. Jimbo
Top Always Down
Dr. Jimbo's Avatar
Crow bar and a big hammer should do the trick.
Seriously, I don't know. Happened on my VW Bug once and I realized that I forgot to disconnect the clutch cable. Not an issue on the S though.
Old 10-28-2009, 10:52 AM   #3 (permalink)
turbosix
did you lower the engine cradle? could be hitting the trans tunnel
turbosix.net
Old 10-28-2009, 11:44 AM   #4 (permalink)
tuna79
tuna79's Avatar
I've got plenty of clearance all around the trans. It should just slide off but something is in a bind. I can rock it all the way around and even spin it on the shaft a bit.
Old 10-28-2009, 02:24 PM   #5 (permalink)
did you remove the clutch fork?
