clutch is slipping need some help
ok i replace my clutch and resurface the flywheel but it still feels like it is slipping.....does any one know what it could be
lol...need more info man.
Super Dooper Senior Newbi
man, no one's tried to buy it yet lol
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats." - H.L. Mencken |
my clutch was slipping so got a stage 2 clutch kit but it feels the same
you have an AP1 so there is no CDV. maybe it's time to change the way you drive.
Have you bled your clutch?
It might be the lack of pressure holding the plates together? i have never messed with my clutch, but it is something you could try to do :/
Enthused Member
After a track meet my clutch was slipping and thought i needed a new clutch but i checked my fluid levels first and found my clutch fuild was low.
That might be your problem??!!$$$* |
Car Dummy
Low clutch fluid or air in the system will cause disengaging problems, not slipping problems.
Raconteur
exactly.
i think the pressure plate does that...clutch fluid has nothing to do with it.
FIGHT THE POWER!!!
You know what will cause a new clutch to slip? Improper break-in.
How many miles did you break it in before you beat the shit out of it again? It sounds like you didn't even break it in. And stage 2? Is this an Ebay clutch? |
One of the cylinders could be binding,
or the flywheel could be undercut. what did the clutch you took out look like? jagg |
the clutch was gone and the fly wheel had some burn spots
Probably not bedded in.
| break, clutch, s2000 |
