Register Forgot Password?
Search
Welcome to the S2000 Forums.
Old 04-16-2011, 01:03 AM   #1
Unhappy Help! cooling fan comes on full speed when ignition on
Both A/C and radiator fans come on fully when ignition on~no matter cold or hot
anyone knows what cause that?~
Thank~
vtec2614 is offline   Reply With Quote
Old 04-16-2011, 08:07 AM   #2
flyingarmadillo's Avatar
Thank~
Well, the radiator one runs off a thermostatic switch - sounds like its gone bad or there's a problem with the wiring harness to it. The other possibility is that the fan relay has gone bad.
Old 04-16-2011, 09:02 AM   #3
adagio's Avatar
Do you have the A/C button pressed? That surprised me once too. My wife had turned on the A/C and then whenever I turned on the key I kept hearing the fans go on.
Too fast for my hat.
adagio is offline   Reply With Quote
Old 04-16-2011, 10:03 AM   #4
General Nuisance
Doug3's Avatar
That's my guess too. Cooling fan is ALWAYS on when the A/C is on.
Last Name: Ever
First Name: Greatest
Doug3 is offline   Reply With Quote
Old 04-16-2011, 02:10 PM   #5
The blower fan has to be on too - it won't do it with just the button pushed on mine.
Old 04-16-2011, 02:32 PM   #6
this is good advice.
S2000
Honda S2000
Paid Advertisement
cooling, fan, fans, full, ignition, key, prizm, radiator, relay, s2000, sounds, speed, turn, turned, wiring
Search this Thread:
Advanced Search
