Old 10-19-2006, 04:50 AM   #1 (permalink)
blacktrojan
6th Gear Acceleration Problem
Just bought a second s2000 a week ago, 1999 with 55000 miles on the clock.
Was driving last night in 6th geat, doing about 50mph, when I floored it the revs increased quite quickly without much acceleration then after a few seconds the car started accelerationg. It seemed almost as thought it changed itself into a lower gear for a few seconds before changing back to 6th. I hope you understand what I am saying.
Is this a feature of s2000?
Does anyone know what the problem could be?
Thanks
blacktrojan is offline   Reply With Quote
Old 10-19-2006, 06:04 AM   #2 (permalink)
Raconteur
Thanks
Sounds like a slipping clutch. Easiest way to determine is to start the car, make sure the car cannot move (handbrake, chock the wheels, park against a tree, etc). Put it into 1st gear and release the clutch slowly. If you can release the clutch without the engine dying, you have a $700 problem (new clutch). If it dies, there may be oil on the clutch plate from a bad rear crank seal in which case you have a $700 problem (new rear seal). I'm just kidding about the replacement costs, but revs increasing without corresponding acceleration is a definite sign of clutch problems. Does the car accelerate normally in 1 through 5th gear?
Old 10-19-2006, 08:00 AM   #3 (permalink)
Slipping clutch would be my guess as well.
Old 10-19-2006, 12:47 PM   #4 (permalink)
blacktrojan
Thanks for the info kgf3076. The car does appear to accelerate properly from 1st through to 5th. In 6th it only happens once in a while. I'll test the clutch out and see
Old 10-20-2006, 04:49 AM   #5 (permalink)
blacktrojan
Problem seems to be getting worst. It must be a slipping clutch. How annoying!
Old 10-20-2006, 11:37 AM   #6 (permalink)
Halo
Halo's Avatar
Odd that it's doing it in 6th though. I vote clutch too, but it should be most noticeable in 1st, shouldn't it?
Old 10-20-2006, 01:16 PM   #7 (permalink)
blacktrojan
It seems to be doing it in all gears now. I guess this is what is called aa "slipping clutch".
The most annoying thing is it was fine when i test drove the car, the day after i bought the car this started happening. How unlucky can a man be?!
Old 10-20-2006, 03:49 PM   #8 (permalink)
jay2000
jay2000's Avatar
Clutches slip easier in higher gears at slower speeds. That is the best way to tell, go 40 or miles per hour in 5th or sixth and it will slip before it will in 1-3. I think torque has something to do with it in the higher gears.
mods:
K&N Fipk
supersprint exhaust
CR rims
voo doo shift knob
alpine head unit, mb quart qsd 216, jl 300/2.
jay2000 is offline   Reply With Quote
Old 10-20-2006, 05:24 PM   #9 (permalink)
HELL_ON_WHEELS
HELL_ON_WHEELS's Avatar
I had the same thing happen to me when I got my 2000 S2000 I only had it for three days and already I had to put $1200.00 for a new clutch
"Drive it like you stole it"
acceleration, clutch, crankshaft, engine, gear, honda, problem, problems, rear, replace, s2000, seal, sixth, slip, slipping
Problem With my S S2000GR All Other Honda S2000 Related Discussions 5 01-31-2007 03:58 PM
problem someone help chocho All Other Honda S2000 Related Discussions 1 08-30-2006 05:25 PM
Car dives to the right after acceleration. Audi/S2K All Other Honda S2000 Related Discussions 9 03-15-2006 04:26 PM
problem zorat8 All Other Honda S2000 Related Discussions 0 11-29-2005 03:54 PM
Anyone had a problem with their S popping out of gear? Evinrude All Other Honda S2000 Related Discussions 2 09-09-2004 03:01 AM
