Old 10-22-2006, 10:48 PM   #1 (permalink)
Tim Gedney
Send a message via AIM to Tim Gedney
Boosted octane...can it take it?
It's not street rod, but I was wondering if I can use special fuel in my relatively stock 2002. There is a race shop nearby that sells pretty sophisticated fuels and I'm curious to see how the car might react with something more than 91 octane in the tank. Thoughts?
Tim Gedney is offline   Reply With Quote
Old 10-22-2006, 10:54 PM   #2 (permalink)
the exact same as it acts right now. As far as i know the s doesnt have different maps to turn up timing with higher octane. Huge waste of money. Now give it some boost and the higher octane gas may help to stop pre detonation
Old 10-23-2006, 06:57 AM   #3 (permalink)
oh and also if you decide to do it just cause you have that much money i think 103 octane is the highest legal one you can use on the street not that we care about silly laws. i used to throw in some 103 in the boosted car i built and my buddy said it was terrible to drive behind me with the windows down his eyes burned like crazy but also I didnt have a cat my exhaust went dp then dumped right behind the front wheel
Old 10-23-2006, 10:22 AM   #4 (permalink)
Halo
Halo's Avatar
I tried some 103 from Unocal after I got the SC installed because it had a grinding noise that I wondered (though seriously doubted) if it could be detonation. It didn't do anything noticeable with the butt dyno since the system is designed to run on 91. (Turns out the grinding noise is just gear lash and most of the Comptechs have it).
Anyway, the only theoretical problem with running race gas is that it is so high octane that it might not fully ignite during the combustion phase and some of it might still be igniting around the exhaust valve as it exits the chamber. I say theoretical since this probably doesn't happen with 103. The point of using 103 would only be if you are tuned to run very high compression and very lean and to prevent detonation. Since our cars are tuned to run on 91, higher octane won't help boost performance by itself.
Old 10-23-2006, 03:28 PM   #5 (permalink)
ya we run 11.1 compression or something like that so no problems using 103 but its not gonna help anything
Old 10-28-2006, 11:55 AM   #6 (permalink)
pecetrn
I have a SC and regularly would put high octane in my car but a couple of months ago my catalytic convertor burnt out (which honda was cool enough to replace under 'extended' warranty). Just regular 91 for me now.
pecetrn is offline   Reply With Quote
2006, honda, octane, s2000
Oil & octane tullymars Engine Tech / Drivetrain 18 02-27-2007 01:54 PM
Boosted octane...can it take it? Tim Gedney Engine Tech / Drivetrain 14 02-02-2007 03:08 PM
High octane Gasoline apostolos All Other Honda S2000 Related Discussions 2 08-24-2005 06:41 AM
