| Register | All Albums | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendors |
| Welcome to the S2000 Forums. |
| If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below. |
LinkBack | Thread Tools | Search this Thread | Display Modes |
#1 (permalink) | |||||
Clutch Pedal way too soft, rough shifting
House of CR.
I would try a clutch bleed/new fluid combined with a clutch pedal adjustment afterward to factory spec's. Then look to other alternatives if the above doesn't improve the clutch feel.
~Steven ![]() ![]() ![]() “Please take good care of your S2000, keep it by your side for long and enjoy it from the bottom of your heart. And share the quality and legacy of the S2000 with many friends so that the legend of the S2000 will continue for long” – Shigeru Uehara. |
Sounds exactly like the MC. Feel the carpet under the clutch pedal and on top of the dead pedal if there is brake fluid you know for sure. Sometimes the seal just starts to let air into the system and it won't actually leak. The SC usually doesn't go bad like the MC.
Price the MC from your dealership but it shouldn't cost more then $80+ shipping http://www.cflhonda.com/parts/2004/H...TER%20CYLINDER Also if you do this yourself stick some newspaper over the hole in between the dead pedal and the side of the car. if one of the bolts falls down there you then have to take the whole plastic side piece off PITA. Also a good long extension with a swivel works great on the bolt closest to the outside of the car. Good luck. Kevin |
Oooo yeah,
Take your time then you put the line back on the MC the threads are small and it isn't in a great spot to work on. TAKE YOUR TIME and don't cross the threads. Kevin |
I agree with VP. Definitely do a clutch bleed first. No point in spending $80 bucks for something you might not even need.
People only hate on the S2000 because they want ridiculous amounts of power to compensate for their lack of driving skills |
Top Always Down
2 beer job. Though I did it last weekend with no beers (I'm on a raw food cleanse). Maybe that's why it took me longer. I bought a CMC from O'reilly for $55. The part that connects to the clutch pedal was shorter that the one that was on the last aftermarket one I had put in. I had to push the clutch pedal down to get the pin to go through and I realized, that ain't right. I unscrewed the one off of the old CMC and it was almost 1/2 inch longer. So I had to get the new one off and replace it with the old connector. Also, my fluid line didn't match up perfect, so I had to rebend it a bit to make it fit without crossthreading. I shoulda stuck with oem, never even checked on the price, I figured it was at least double of aftermarket.
When you bleed the system, make sure you put the cap back on the reservoir otherwise it will shoot out when the pedal is pumped (and that sh!t eats paint). Also, don't go more than 4 or 5 bleeds before you fill the reservoir or you'll be sucking air and starting all over again.
i've never done mine (done under warranty by acura) so i wouldn't know, but is it possible to at least start the threads before attaching the MC to the firewall? maybe give you a bit more room?
Top Always Down
I wish I'da done that with the fluid line before I cinched the CMC into place. I thought about it after the fact.
Party Rock Crew
starrman
#10 (permalink) | |
well I went ahead and ordered both MC and SC just to be safe. Need to find a hydraulics shop tomorrow morning to get a new soft line whipped up then the fun will commense.
Thanks again guys, much appreciated!
#11 (permalink) | |
Kevin |
#12 (permalink) | |
temporary solution at best......the same effect can be achieved by pumping the clutch pedal several times before trying to engage any gear from neutral. (if the clutch had been recently replaced, I would agree with this advice as long as a visual inspection of the clutch hydraulics revealed no leaks.) sounds like you're on the right track Kalm. jagg |
Party Rock Crew
Probably a wise move, hate to change one and then find out a little later the other failed... Good luck with the install.
starrman
#14 (permalink) | |
Thanks again guys - install was not difficult at all - not even 1 bloody knuckle!
On the frustrating side, however, the new slave cylinder broke itself, the piston was out of round or something. Soon as we started bleeding it, it went cockeyed in the cylinder housing and literally destroyed itself breaking the housing apart, leaking fluid all over the driveway at my mother's house. Fortunately as it turns out, the SC was not the problem at all, so I simply put the old one back on, bled the system and have been sailing smoothly since. Lesson learned... stealership parts aren't impervious to being faultily built.
House of CR.
Glad it worked out for you!
#16 (permalink) | |
haha, well the master cylinder WAS the problem. It had leaked all over inside below the pedal.
#17 (permalink) |
Glad you got it all figured out Kalm!!
WE ARE ALL PART OF A UNIQUE BROTHERHOOD. THE BROTHERHOOD OF THE "S". ![]() MY2000 #2249 MODS: APR carbon fiber spark plug cover, Megan Racing test pipe, Megan Racing drift spec catback exhaust, K&N drop-in filter, Tanabe NF210 springs, Rick's smoked side markers, OEM front lip, AP1 OEM wheels painted black w/chrome lip, OEM leather wrapped shift knob |
| adjustment, clutch, engage, forum, low, pedal, point, release, rough, s2000, set, shifting, soft, spot, wont |
| X vBulletin 3.8.7 Debug Information | |
More Information |
Template Usage:
Phrase Groups Available:
Included Files:
Hooks Called:
