Register Forgot Password?
Welcome to the S2000 Forums.
submit to reddit
Old 02-04-2012, 11:13 AM   #1 (permalink)
03ap1s2k's Avatar
Changing my ap1 clutch
I'm changing my clutch and there is one bellhousing bolt I cant get to, right under the intake manifold.. Any suggestions would be great!
Thanks
03ap1s2k is offline   Reply With Quote
Old 02-04-2012, 11:19 AM   #2 (permalink)
TheCarGuy2021's Avatar
The upper starter bolt? Grab a flashlight and from the front of the engine go at it with a long extension and universal joint on the socket. I lined the socket with tape so it would be a tight fit and the bolt wouldn't fall out once I unscrewed it. With the air box and alternator removed it is fairly easy to get out. The bolt also should be marked with red paint and it helps to have the front of the car jacked up to reduce back stress.
Good luck!
Old 02-05-2012, 04:30 PM   #3 (permalink)
03ap1s2k's Avatar
Thanks alot, thats what I did and it was difficult but thats the only way to do it without dropping the motor and tranny as alldata shows
Old 02-06-2012, 05:51 AM   #4 (permalink)
I've heard that bolt can be a real bi*ch to get at. Good luck with the install!
WE ARE ALL PART OF A UNIQUE BROTHERHOOD. THE BROTHERHOOD OF THE "S".
MY2000 #2249 MODS: APR carbon fiber spark plug cover, Megan Racing test pipe, Megan Racing drift spec catback exhaust, K&N drop-in filter, Tanabe NF210 springs, Rick's smoked side markers, OEM front lip, AP1 OEM wheels painted black w/chrome lip, OEM leather wrapped shift knob
Old 02-14-2012, 07:38 AM   #5 (permalink)
03ap1s2k's Avatar
Yeah it was, I called it alot more than just a bitch lol but got it done now
Old 02-16-2012, 01:09 PM   #6 (permalink)
project ap2's Avatar
its pain it the a** getting to that bolt...i gave up and just ended up removing the engine mounts and dropping the engine as much as i could...how did you do it?
project ap2 is offline   Reply With Quote
Old 02-17-2012, 03:32 AM   #7 (permalink)
03ap1s2k's Avatar
I unbolted the k member bolts and dropped the motor down as far as I needed to, and took out the air box to have enough room for a good angle to go under the intake
S2000
Honda S2000
Paid Advertisement
submit to reddit
aldata, ap1, bolts, changing, clutch, fit, forum, honda, life, long, motor, removal, review, s2000, series, transmission
Search this Thread:
Advanced Search
Contact Us - S2000 Forums - Archive - Top
X vBulletin 3.8.7 Debug Information
  • Page Generation 0.14330 seconds
  • Memory Usage 5,496KB
  • Queries Executed 8 (?)
More Information
Template Usage:
  • (1)SHOWTHREAD
  • (1)ad_footer_end
  • (1)ad_footer_start
  • (1)ad_header_end
  • (1)ad_header_logo
  • (1)ad_navbar_below
  • (1)ad_showthread_beforeqr
  • (1)ad_showthread_firstpost
  • (1)ad_showthread_firstpost_sig
  • (1)ad_showthread_firstpost_start
  • (1)album_all_navbar_link
  • (1)album_all_quick_links
  • (1)footer
  • (1)forumrules
  • (1)gobutton
  • (1)header
  • (1)headinclude
  • (1)navbar
  • (3)navbar_link
  • (1)navbar_links_loginbox
  • (3)option
  • (7)postbit_legacy
  • (7)postbit_onlinestatus
  • (7)postbit_wrapper
  • (1)social_thread_share_headinclude
  • (1)spacer_close
  • (1)spacer_open
  • (1)style_analytics_tracker
  • (16)tagbit
  • (1)tagbit_wrapper
  • (1)vbnexus_buttons
  • (1)vbseo_linkbackmenu
  • (1)vbseo_linkbackmenu_entry
Phrase Groups Available:
  • global
  • inlinemod
  • postbit
  • posting
  • reputationlevel
  • showthread
  • vbnexus
Included Files:
  • .//var/ibvbshare/vbseo/3.5.2/vbseo.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_pre.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_url.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_createurl.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_db.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_vb.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_seo.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_misc.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_crr.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_cache.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_hook.php
  • .//var/ibvbshare/vbseo/3.5.2/vbseo/includes/functions_vbseo_startup.php
  • ./includes/config.php
  • ./showthread.php
  • ./global.php
  • ./includes/init.php
  • ./includes/class_core.php
  • ./includes/functions.php
  • ./includes/class_hook.php
  • .//var/ibvbshare/vbnexus4.1.5/vBNexus.php
  • .//var/ibvbshare/vbnexus4.1.5/vBNexus_fb.php
  • .//var/ibvbshare/vbnexus4.1.5/vBNexus_user.php
  • ./includes/functions_login.php
  • .//var/ibvbshare/vbnexus4.1.5/facebook-php-sdk/facebook.php
  • .//var/ibvbshare/vbnexus4.1.5/facebook-php-sdk/base_facebook.php
  • .//var/ibvbshare/vbnexus4.1.5/vBNexus_gfc.php
  • ./includes/functions_album.php
  • .//var/ibvbshare/autocomm_master/jquery.php
  • ./includes/functions_bigthree.php
  • ./includes/class_postbit.php
  • ./includes/class_bbcode.php
  • ./includes/functions_reputation.php
Hooks Called:
  • init_startup
  • cache_permissions
  • fetch_threadinfo_query
  • fetch_threadinfo
  • fetch_foruminfo
  • style_fetch
  • cache_templates
  • global_start
  • parse_templates
  • global_setup_complete
  • showthread_start
  • showthread_getinfo
  • showthread_post_start
  • showthread_query_postids
  • showthread_query
  • bbcode_fetch_tags
  • bbcode_create
  • showthread_postbit_create
  • postbit_factory
  • postbit_display_start
  • fetch_musername
  • postbit_imicons
  • bbcode_parse_start
  • bbcode_parse_complete_precache
  • postbit_display_complete
  • tag_fetchbit
  • tag_fetchbit_complete
  • forumrules
  • navbits
  • navbits_complete
  • showthread_complete
