Old 12-30-2006, 03:55 AM   #1 (permalink)
Qs2k
Question transmission question! help please!
Hello everyone. I just bought an 2001 s2k. When I test drove it, it was fine. Now that I have the car, I notice that when I get into a gear for example 5th gear. After getting into gear I would let go of the gas and then I hear like a grinding sound. I get worried and just shift the gear. I don't know if this is normal or not. Any help would be great. Thank you
Qs2k is offline   Reply With Quote
Old 12-30-2006, 06:23 AM   #2 (permalink)
Welcome aboard Qs. 'Afraid that I can't offer much other than what I'd do in a similar situation.
The site serves a whole bunch'a purposes n' does most of 'em well, but the diagnosin' of problems isn't exactly where it shines. Noises n' such defy most of us in translation into words, n' that gets further complicated n' muddied by the reader translatin' it into somethin' that makes sense at his/her end.
If it's somethin' that sounds like it could be trouble n' possibly be doin' damage, I'd get it to a reputable mechanic r' maybe even mother Honda to ease any apprehension.
Especially in a case such as yours, where you've jus' picked your new ride up, mention it n' ask 'em to eyeball everythin' n' round up the usual suspects while they're checkin' out that grindin' sound. There's alodda relief to be had by gettin' the blessin' of a good mech.
'Probably not what you wanted to hear, but it's the best I got.
Be well n' good luck.
Old 01-02-2007, 10:52 AM   #3 (permalink)
Bubblerboy64
Well I think we would all agree its not normal. If you have grinding going into gear I would suspect the clutch first and then the transmission syncros. Certainly time to get "professional" help.
Old 01-02-2007, 02:51 PM   #4 (permalink)
Qs2k
well it doesnt make the grinding sound when im getting into gear. it makes it when im already in a gear and when i let go the gas?
Old 01-02-2007, 03:32 PM   #5 (permalink)
Bubblerboy64
Go back and read my post of a couple months ago titled "exhaust rattle?" See if this tells you anything. You use the term "grinding" the noise I had was more of a vibration or rattle then a grinding sound. If it is in fact grinding then I would have to think the transmission itself is bad. The letting off the gas however makes me wonder if you are experiencing the same thing I did. If it ONLY happens when you let off the gas and are engine braking and slowing without applying the brakes then I would suspect the clutch. Replacing the clutch seems to have completely cured my problem but I would never have characterized the sound as grinding. John H
Old 01-19-2007, 08:25 PM   #6 (permalink)
Vezna31
Vezna31's Avatar
I get some grind when going into 5th when driving harder and I know it's my synchros, but I haven't heard of it making noise other than for the decel buzz that some cars have. I only get that once in a while in either 2nd or 4th gear. Doesn't happen often. Maybe this is what he is experiencing?
http://www.vezna.com
Old 01-19-2007, 10:20 PM   #7 (permalink)
spa01s2k
spa01s2k's Avatar
I agree, I think that maybe what he was hearing. My 2001 does have a bit of clutch buzz on decel in 3-5 gear. Not hurting anything, just a bit annoying. Can be fixed by replacing the clutch.
2001 Honda S2000
1991 Honda Prelude
1994 Ford Bronco
Old 01-20-2007, 06:49 AM   #8 (permalink)
Yeah . . "maybe".
Ta my way'a thinkin' it's time to determine jus' how nervous you are about it Qs. Nervous enough to get it checked, or, can ya settle in with a wait-n'-see, with a heavy dose'a havin' yer fingers crossed?
Be well n' good luck . . n' like the old knight said . . .
Old 02-12-2007, 02:09 AM   #9 (permalink)
Qs2k
just its the clutch buzz. theres no harm. honda quoted me $900 to get it replaced
02, 04, 05, cllutch, ew, grinding, mechanic, oesnt, s2000, sale, shift, sound, trans, transmision, transmission
2005 S200 transmission Scottky Engine Tech / Drivetrain 14 07-02-2007 07:24 PM
Transmission/synchros problem? smalls777 All Other Honda S2000 Related Discussions 4 07-18-2006 08:14 AM
Transmission Noise cfahey03 All Other Honda S2000 Related Discussions 2 06-10-2005 08:32 AM
Transmission gcrum All Other Honda S2000 Related Discussions 1 02-05-2005 11:02 PM
Transmission Worries and Tire Concerns Anonymous All Other Honda S2000 Related Discussions 1 01-29-2004 11:20 AM
