Old 01-16-2007, 06:34 AM   #1 (permalink)
stewie69
Growl In Tranny
Im looking at a 2001 stewie silverstone metallic. Any way when I test drove it, it had a growl in the tranny I mentioned it to the dealer and he said that all of them had that noise. Is it normal do they all have a noise in the tranny kinda like its winding?
stewie69 is offline   Reply With Quote
Old 01-16-2007, 10:20 AM   #2 (permalink)
Scott
Scott's Avatar
The transmission is noisier than most, but a growl? I don't know about that. Maybe just in reverse and at very low RPM. But even then, I don't think I would call it a growl.
1966 Ford Mustang
2003 Land Rover Freelander
Old 01-16-2007, 10:41 AM   #3 (permalink)
bladerunner
bladerunner's Avatar
only odd noises I noticed when I got my car was some ticking at idle and the service tech said it was the injectors acting normally. No other worrysome mechanical noise, yet. 9100 miles
Old 01-16-2007, 05:35 PM   #4 (permalink)
Scott
Scott's Avatar
I've given some more thought about it. The "winding" noise you described is common for the Reverse gear. However, it shouldn't be doing it in the forward drive gears.
1966 Ford Mustang
Old 01-16-2007, 07:59 PM   #5 (permalink)
spa01s2k
spa01s2k's Avatar
Is the growl all the time, or is there a more certain time that it happens (accel, decel)?
2001 Honda S2000
1991 Honda Prelude
1994 Ford Bronco
growl, low, noise, rpm, s2000, s2k, tranny, transmission
Engine oil & Tranny fluid cpiercecf Engine Tech / Drivetrain 11 04-27-2007 10:26 AM
Tranny and Clutch questions Hi_Psi Engine Tech / Drivetrain 0 03-22-2007 08:56 AM
Diff oil & tranny oil arprice Engine Tech / Drivetrain 6 01-21-2007 02:10 PM
Moby 1 in my tranny and diff ok? Tyraid2K All Other Honda S2000 Related Discussions 1 05-30-2005 04:54 PM
Rough Tranny? spdracr929 All Other Honda S2000 Related Discussions 3 01-08-2004 10:50 PM
