Old 01-17-2007, 05:52 AM   #1 (permalink)
DMC_S2000
DMC_S2000's Avatar
Send a message via Yahoo to DMC_S2000
Exclamation Question about redline...
I just wanted to ask...how can you boost the redline of an engine(especifically AP2 engine) by just using Perfomance ECU? and how can really the ECU raise the redline if the nature of engine heats up at its redline?
DMC_S2000 is offline   Reply With Quote
Old 01-17-2007, 06:13 AM   #2 (permalink)
Curious as to the purpose of boostin' the redline D. Just raisin' the redline doesn't necessarily increase power n' has you treadin' where the factory don't wanna know nothin' when @*#& happens, n' we all know that @*#& happens.
I'm assumin' that this is about more power?
'Cause higher redlines r' more about braggin' rights while sittin' 'roun' the campfire than they are about useable power.
Old 01-17-2007, 07:20 AM   #3 (permalink)
Java is correct. Raising the red line will do nothing for power. I can't speak for the F22 but the F20's peak power is about 8600 RPM's. After that, you are on the down side of the power curve.
Old 01-17-2007, 06:47 PM   #4 (permalink)
bobby2002S2K
bobby2002S2K's Avatar
Bottom line no need to exceed the red line unless your motor is rebuilt for it.With out doing that theres going to be no power and you will just be tearing *&%$ up.
Old 01-17-2007, 07:10 PM   #5 (permalink)
it is a car not a motorcycle................
Old 01-18-2007, 01:28 AM   #6 (permalink)
Well-l-l-l-l . . . it is a car, but . . . the engine . . . . . .
There's alodda sportbike-think in Stewie's heart.
Old 01-18-2007, 11:46 AM   #7 (permalink)
Vezna31
Vezna31's Avatar
A performance ECU may boost the redline a few hundred RPM. I had a Hypertec in my old '95 Z28 that boosted redline from 5250 to 6000 RPM. There were small HP gains from it mainly because it changed the air-fuel mixture and (I think) the timing. I don't know what kind of changes one would do in an S2000, but the power curve begins begins to dip in the low 8's as GoMarlins3 said earlier.
A better buy (and cheaper) might be an intake, like K & N, where it will add about 9.5 HP between 6500-8500 RPM, but not the overall HP.
http://www.vezna.com
8600, ap2, ecu, engine, f22, increase, line, raise, raises, raising, red, redline, rpm, s2000, s2k
about the redline of '06 S2000 DMC_S2000 All Other Honda S2000 Related Discussions 1 06-24-2006 11:33 PM
