Old 01-24-2007, 02:42 PM   #1 (permalink)
papak
Fuel quality?
Are there multiple or adaptive fuel maps in the engine management computer to adapt to the variations in octane rating and fuel quality?
TIA
papak is offline   Reply With Quote
Old 01-24-2007, 07:12 PM   #2 (permalink)
spa01s2k
spa01s2k's Avatar
Engines have a lot of sensors to tell the computer how the car is running. When you put different gas in your car it will change a few different things, such as the amount of fuel going in and spark timing. When you use a lesser grade of fuel (or poorer quality), your engine will run differently and the sensors will pick that up. The computer will then make the correct adjustments to make the car run efficiently, but not as efficient as with better gas.
2001 Honda S2000
1991 Honda Prelude
1994 Ford Bronco
91, filter, fuel, gas, s2000
Fuel systems questions... MZsS2000 All Other Honda S2000 Related Discussions 4 05-24-2007 02:03 PM
Fuel filter & cats Black S2000 Engine Tech / Drivetrain 1 03-25-2007 10:59 PM
Honda S2000 and Quality Helmut All Other Honda S2000 Related Discussions 11 09-01-2005 03:48 PM
Where's the fuel release located johnlcrain All Other Honda S2000 Related Discussions 3 12-30-2003 11:16 AM
