Old 02-04-2007, 09:10 AM   #1 (permalink)
MADMAX27330
Skunk 2 lowering spring PROBLEM!!!
Whats up guys, have a quick question for you. I just drop my s2000, 2' (9 loops) front 1.8' (8 loops) in the back, but the back looks lower than the front, please let me know if I installed it right or if it's suppose to look like that!!!
MADMAX27330 is offline   Reply With Quote
Old 02-04-2007, 05:11 PM   #2 (permalink)
bobby2002S2K
bobby2002S2K's Avatar
did you measure your ride height before you put them on and then after you got them on remeasure?If so and the rear is lower something is not on correct maybe not sitting in the perch correctly in the front would me my guess and would be the first thing i would look at.Second i would insure that i didnt put the back springs on the front.
Old 02-05-2007, 06:36 PM   #3 (permalink)
MADMAX27330
ok how can i measure it with the front fender is sitting high then the back one is?? or does that matter??
Old 02-05-2007, 07:14 PM   #4 (permalink)
karnito
karnito's Avatar
You should lower them evenly. Is this coild over ?
[HAD an 00 GReddy S2K] [06 Porsche Carrera]
Old 02-06-2007, 04:22 PM   #5 (permalink)
MADMAX27330
no springs!!!
Old 02-06-2007, 05:33 PM   #6 (permalink)
karnito
karnito's Avatar
Originally Posted by MADMAX27330 View Post
no springs!!!
May be that is the problem.
Old 02-07-2007, 04:46 PM   #7 (permalink)
MADMAX27330
what do u mean? whats wrong is with spring's???
Old 02-07-2007, 06:37 PM   #8 (permalink)
karnito
karnito's Avatar
Oh, this is not a coild but the lowered springs.. Sorry for thre mis-understanding. 1/4 is different isn't that bad.
Old 02-09-2007, 07:03 PM   #9 (permalink)
bobby2002S2K
mesurements.
It doesnt matter because you get your base measurement before you lower it just like it sits and then after you lower it measure the same way you did the base mesurement. How high the fenders are has nothing to do with it, its the measured change that means something. The number that you get after you subtract Your lowered mesurement from the base mesurement.
2, 2s, change, honda, long, lowered, lowering, pics, rear, rears, s2000, short, skunk, skunk2, spring, springs
Lowering it. sonic Wheels / Tires / Suspension 3 07-26-2007 10:09 PM
stock spring rate? bobby2002S2K Wheels / Tires / Suspension 5 02-20-2007 09:15 PM
what's the best lowering spring for s2k !!! Yahoo All Other Honda S2000 Related Discussions 9 10-24-2006 08:34 PM
lowering...camber? soon2be All Other Honda S2000 Related Discussions 3 06-21-2006 04:53 PM
Rubber block attached to FR Drivers side spring New02 All Other Honda S2000 Related Discussions 5 04-09-2004 06:29 PM
