help
has anybody had any issues with your suspension poping or making any noise while on uneven ground or from a stop?
Yes, it will happen, but I am not on a stock suspension any longer so mine may not be the best judgement to go on.
Metallic "pops" always send me to check that everything is tightened to where it's supposed to be. The most obvious would be the wheel lugs n' then, check the suspension n' if that checks out, move right up the power delivery chain.
Other than expansion n' contraction of hot metal, pops usually mean that there's some slop someplace where there ain't supposed to be any. Be well n' good huntin'. Java
my front right does that on a brand new coil over. I check everything and everything is tied. Usually that's associate with the mounting pillow and its pushing.. Anyway, I might just have to replace that suspension just to see if that is the case...
[HAD an 00 GReddy S2K] [06 Porsche Carrera] |
yea my front sqeeks when crossing speed bumps or going slow over uneven surface.Make me want to lube some ball joints but your not doing that on a stock honda ball joint,lol.
I don't know what it is but it is an anoying "clunk" that bothers me..
THATS IT A "CLUNK"!!!!!! thanks karnito finally someone else knows but I'm on stock suspension
Strut mount then.
I'm going to get under the car this weekend and check to see if anything is loose(won't be the first time I found something the Honda dealer missed)
I checked my yesterday but couldn't find a thing... I thought it was the subframe in the front.
I know there is a service bulletin for popping and creaking noises in the rear on the 00-02 models. What model is yours?
Don't know if this applies to your situation but hope it helps
It's publication #011217 Axle Pops or Creaks: ’00–02 S2000 On 0002 S2000s, if your customer complains of hearing a single pop or creak from the rear of the vehicle when changing direction from forward to backward and vice versa, the problem may be axle (driveshaft) movement in the rear hub. To eliminate the noise, replace the spindle nut on the affected axle. Apply grease to the surface of the new spindle nut where it contacts the hub. Torque the new nut to 298 N·m (220 lb-ft), and stake the nut. |
| 2005, bumps, changing, creak, creaking, hub, nut, pop, replace, s2000, slow, speed, spindle, suspension |
