Old 04-09-2007, 09:40 PM   #1 (permalink)
leo520
questions about:Engine Torque Damper?
huy guys one of my friend puts Engine Torque Damper into his Scion Tc. and he said it's going to be more feel lot better while u drive fast cause the engine doesn't shake and vibration hard like original..
can someone tell does this thing work for the s2000??
and what if i install it and will i still have the Honda's warranty?
Old 04-09-2007, 10:22 PM   #2 (permalink)
The joke with these is that your engine is suppose to have some torque for this mod to be of any help and we all know the S has no torque.
Some people have bought them and claim they 'feel' a difference, but then others have said they 'feel' a difference with a STB and that has basically been proven to be of no value for stiffening the chassis.
My thought on TD's is that if you like it, go for it. As for your warrenty, I would guess it wouldn't hurt it because you could always remove it when you took the car to Honda.
Old 04-11-2007, 07:45 PM   #3 (permalink)
leo520
aright thx agian.
Old 08-24-2008, 02:54 PM   #4 (permalink)
fatality122887
i had one on my 07 si and it made a big difference on my launch and my shifting. no matter how much TQ your motor has it is going 2 rock in its mounts. the idea behind the ETD is that instead of the TQ rotating the motor it will rotate your tires so you put all the power to the ground. it helps a lot with wheel hop in a front wheel drive car idk about what it would do in a RWD. i'm not planning on getting one it makes the engine noise inside the car so freaking loud its not even funny. and it makes the whole car vibrate like crazy cuz the engine is dirrectly linked 2 the car. just look up the advantages of having stiffer engine mounts and thats basically what you get just cheeper, with less work, and not to the maximum effect you could get with replacing your mounts.
fatality122887 is offline   Reply With Quote
2008, automatic, cost, dampener, damper, engine, forum, honda, install, replacing, s2000, scion, tc, toque, torque
torque tuning help DMC_S2000 Engine Tech / Drivetrain 3 03-01-2007 02:06 PM
s2000 engineand torque? mikeperformance21 Engine Tech / Drivetrain 8 02-09-2007 07:35 PM
How To Adjust Damper Force? S2K_NOOBiee_G Wheels / Tires / Suspension 1 10-24-2006 08:55 PM
lug nut torque Captainnice All Other Honda S2000 Related Discussions 0 12-04-2005 12:11 PM
153 ft-lbs Torque... kccane All Other Honda S2000 Related Discussions 6 04-11-2004 06:32 PM
