Old 04-16-2007, 01:31 AM   #1 (permalink)
Black S2000
Overheating. help!
Car was running fine before. But I just had to change all the fluids as I tend to drive it hard. After flushing & bleeding the system for the 3rd time, it still overheats in traffic. Temp Bar shows 4-5 strips when idling / slowing down. Goes back to 3 strips when moving again. Am I forgetting something? Thank's
Black S2000 is offline   Reply With Quote
Old 04-16-2007, 03:02 AM   #2 (permalink)
griffon
You didn't disconnect the electric radiator fan(s) by accident, did you? Or blow a fuse?
griffon is offline   Reply With Quote
Old 04-16-2007, 04:11 AM   #3 (permalink)
Black, Grif's suggestion's a good one.
Especially in cases where work's jus' been done before a problem arises (you ain't leavin' anythin' out on us r' ya? Like it overheated before the fluid changes?) I always drop back n' retrace all the steps of the work.
Okay, I think I'm followin' you on the flushin' of the systems . . but bleedin' . . . you're talkin' brakes?
I know you've already done this, but, recheck your oil n' coolant levels n' anythin' else that you may've done durin' your fluids replacement.
Keep us posted, good luck, n' be well.
Old 04-16-2007, 08:37 AM   #4 (permalink)
SpoonS2K
SpoonS2K's Avatar
Send a message via MSN to SpoonS2K
I work at a shop, we do rad flushes and a common problem is getting air pocket in your coolant...basically that means when your flushing your rad/coolant through your engine, an air pocket manages to get in usually through the resevoir from not clamping the resevoir hose...a result of that is fine temperature until the air pocket circulates through your thermostat and gets very hot...Im not sure if you flushed it though...
SpoonS2K is offline   Reply With Quote
Old 04-16-2007, 09:47 PM   #5 (permalink)
Black S2000
Ok, thank's guys for your help. I will check through everything you guys mentioned.
Old 04-20-2007, 07:47 PM   #6 (permalink)
griffon
Did you find the problem?
Old 04-30-2007, 12:00 AM   #7 (permalink)
Black S2000
Fans are dead, that's why
Old 04-30-2007, 07:58 PM   #8 (permalink)
SpoonS2K
SpoonS2K's Avatar
Motors are dead then im assuming?
