Old 04-17-2007, 11:27 PM   #1 (permalink)
cpiercecf
So many opions
Should I use the MTF or GM Syncromesh or Redline or........ I am getting the 607 Almasol for the diff. and I am switching to Mobil 1 so now I need to know what tranny fluid I should get. I heard that the new MTF is only smooth for the first 2000 or so miles. I just need a heads up. Thanks again guys
cpiercecf is offline   Reply With Quote
Old 04-18-2007, 10:19 AM   #2 (permalink)
I use the same in the diff and engine as you are and also use the new Honda MTF with no problems so far. Changed it 9,000 miles ago.
Old 04-19-2007, 01:38 PM   #3 (permalink)
cpiercecf
Thanks again Go you seem be on top of every topic. Appreciate your once again. I also ordered the fill and drain plug washers for the tranny and diff. Do I have to replace them everytime I change the fluids? And how much diff. fluid do I need as well as tranny fluid. Thanks!
Old 04-19-2007, 05:34 PM   #4 (permalink)
spa01s2k
spa01s2k's Avatar
It is a good idea to replace the crush washers every time you change your fluids. Its cheap insurance that the plugs don't drip. You should only need 2 quarts for the trans and 1 quart for the diff. BTW - I use MTF for my trans, I change it about every 15K. It seems to do just fine.
2001 Honda S2000
1991 Honda Prelude
1994 Ford Bronco
Old 04-19-2007, 05:54 PM   #5 (permalink)
^What he said!!
Old 04-19-2007, 07:37 PM   #6 (permalink)
cpiercecf
Do you guys know of anyone on this forum that sells the " New MTF " as opposed to going to the dealer and getting the old stuff?
