Old 05-03-2007, 10:12 AM   #1 (permalink)
Estukay
Estukay's Avatar
Rear End Out Of Commission
A few weeks ago when i launched up against a 350, i stripped 2 of my gears at the rear end; primary and the input. The whole hub rear end assembly is down. When i shift in gear, it will pull a little bit, but then grind and the shims would catch nothing. Anybody know where i can find a used decent rear end?
_____________________________________________
Carolina Stewie Rider~
Temple OF all VTEC-s2k
Estukay is offline   Reply With Quote
Old 05-03-2007, 10:34 AM   #2 (permalink)
You might try a salvage yard and I have seen some on eBay. Either way, you don't know what you are really getting. If you want a new one, I can point you to a good vendor.
Old 05-03-2007, 11:46 AM   #3 (permalink)
Estukay
Estukay's Avatar
i guess that would only be the right and smart thing to do for what i've put my little stewie through huh? lol. where can i get one at a good price then?
Old 05-03-2007, 04:49 PM   #4 (permalink)
I had HTG build me one awhile back.
hardtopguy.com :: HTG PERFORMANCE PRODUCTS :: Complete 4.56 ratio final drive gear ****NEW**** in stock
You might want to call him and see what he can do for you. Jeff is a great guy to work with. I have purchased quite a few items from him over the years.
Old 05-04-2007, 05:41 AM   #5 (permalink)
Estukay
Estukay's Avatar
Thanks again for the help. I'll update on the fixin'!
Old 05-04-2007, 12:01 PM   #6 (permalink)
'Sorry to hear 'bou'cher rear Estu, but it sounds like somethin' that you were gonna goddadoo sooner r' later anyway. Leastwize with that beefed up, it's one component that you shouldn't godda worry about again.
'Only trouble with hammerin' heavy HP through light-duty r' "weight-efficient" parts is, that when you replace one piece, the next weak-link in the chain moves up n' takes it's place in line.
Good luck with the fix. (As you didn't bring it up, I don't 'spect that you at least got the satisfaction n' bagged the 350)
Old 05-04-2007, 05:21 PM   #7 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
You might check this link. One S owner has a diff for sale.
Forums -> Things for sale... VOLKS LE37T Gunmetal
Good luck.
batguano is online now   Reply With Quote
« Spark Plugs | Tsb »
Low End Power Silver_06_S2k Engine Tech / Drivetrain 23 03-19-2007 09:11 PM
Strange whine coming from rear end???? jpHPD05 All Other Honda S2000 Related Discussions 11 08-25-2005 09:45 AM
Rear-end clicking jay_pdx2000 All Other Honda S2000 Related Discussions 7 07-04-2005 04:00 AM
Front end aesthetics ShadowJack All Other Honda S2000 Related Discussions 2 10-06-2004 11:22 AM
Squirlly back end/Rear Camber adjustment Anonymous All Other Honda S2000 Related Discussions 3 10-11-2003 04:45 PM
