Old 05-15-2007, 05:25 PM   #1 (permalink)
cpiercecf
Fujita
I just installed a Fujita and everything went fine. I took down the block and it was great. I came home and left 1 hour later and my check engine light is on. Is this normal or do I have some lines connected wrong
cpiercecf is offline   Reply With Quote
Old 05-15-2007, 06:13 PM   #2 (permalink)
Scott
Scott's Avatar
Any idea which code it's throwing?
1966 Ford Mustang
2003 Land Rover Freelander
Old 05-15-2007, 07:39 PM   #3 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
Did you try disconnecting your neg battery terminal for a few minutes? Might just need to reset the ECU.
batguano is online now   Reply With Quote
Old 05-15-2007, 07:39 PM   #4 (permalink)
cpiercecf
no idea. How could I find out
Old 05-15-2007, 08:59 PM   #5 (permalink)
Scott
Scott's Avatar
Any Autozone/Advance Discount Auto/Pep Boys can plug an OBDII scanner into your car and tell you what code the ECU is throwing. They offer the service for free.
1966 Ford Mustang
Old 05-15-2007, 09:48 PM   #6 (permalink)
cpiercecf
I disconnected the battery and it went off. I guess if it comes on again I will go t o Pepboys or something like you said. Thanks guys
Old 05-16-2007, 06:47 AM   #7 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
Glad to help
New Fujita member with ?s JRZ Engine Tech / Drivetrain 2 07-05-2007 01:12 PM
