Old 05-25-2007, 03:37 PM   #1 (permalink)
john
clutch/oil filters
Was wondering what type of oil filters you guy's suggest? Also I have a 2004 model and have read somewhere at sometime, ( getting a little forgetful ) that there's a sensor or safety devise somewhere on the clutch assembly on the 04 models that wont let you speed shift or if the r's are to high it acts kind of like the rev limiter or something like that. Any help on these matters would be greatly appreciated.
Old 05-25-2007, 03:42 PM   #2 (permalink)
Grumpy old(er) phart
I use only Honda oil filters (you can get them cheap if you buy a case). There is a clutch "fast release limiter" valve on the clutch assembly which can be removed. It releases the clutch slowly at high rev's and quick shifts (it's a PITA). First time that thing kicked in, I thought I had a slipping clutch.
Old 05-25-2007, 05:28 PM   #3 (permalink)
S2000dude
S2000dude's Avatar
Hey John !
The OEM Honda oil filter you want is #15400-PCX-004
Goes for about 6-7 bucks.
Old 05-25-2007, 05:44 PM   #4 (permalink)
john
Thanks for the help, do you remember where you read about the PITA?
Old 05-25-2007, 05:45 PM   #5 (permalink)
john
Thanks for the part#, is that for the ap2 or does it matter?
Old 05-25-2007, 07:34 PM   #6 (permalink)
Scott
Scott's Avatar
Yes, the clutch delay valve is a pain in the butt. I'm very glad my '02 didn't come with one.
As for oil filters, I've never used anything but K&N filters in my Honda. They cost a bit more than regular off-the-shelf filters, but every independent test I've read has praised them to no end. And one feature I really love about them is they can be put on and taken off with a standard socket wrench (17mm if I remember correctly).
The K&N oil filter part number is HP-1004.
1966 Ford Mustang
2003 Land Rover Freelander
Old 05-25-2007, 10:48 PM   #7 (permalink)
bladerunner
bladerunner's Avatar
Would that explain why I can't get my tires to chirp on agresssive up shifts? I just assumed the car wasn't powerful enough.
Old 05-26-2007, 07:46 AM   #8 (permalink)
john
Hey thanks!
Old 05-26-2007, 09:18 AM   #9 (permalink)
Scott
Scott's Avatar
Quite possibly. What kind of tires are you running in the rear?
1966 Ford Mustang
Old 05-27-2007, 12:11 PM   #10 (permalink)
bladerunner
Nothing really that sticky at all, the Potenza RE750. Treadwear of 340.
Not that it's my goal to chirp the tires on gearchanges, but most other manual-trans cars I've driven you'll ocasionally get rubber on the 1-2 shift and sometimes higher on more powerful cars.
Old 05-27-2007, 02:46 PM   #11 (permalink)
I have used Fram filters on every car I have own for the past 24 years and have had no problems.
Clutch cpiercecf Engine Tech / Drivetrain 3 05-11-2007 06:38 AM
Diff oil & tranny oil arprice Engine Tech / Drivetrain 6 01-21-2007 01:10 PM
clutch passmans2kNY All Other Honda S2000 Related Discussions 0 10-25-2005 01:32 PM
K&N Filters Sports Compact Fall Nationals FrankieFive News & Special Announcements 0 09-07-2004 11:59 AM
Oil Stick to check oil.... kccane All Other Honda S2000 Related Discussions 1 07-04-2004 08:32 PM
