Old 06-04-2007, 01:29 PM   #1 (permalink)
gogo18
oil problem?
Hello,
I am thinking of buying a used 2002 S2000. I have heard many of these s2000 burn oil and needs regular top up. Anyone have encountered this problem? Thanks
gogo18 is offline   Reply With Quote
Old 06-04-2007, 08:10 PM   #2 (permalink)
S2000dude
S2000dude's Avatar
Gogo- welcome.
If the car was properly broken in there shouldn't be an oil prob. During the break in period you may encounter oil loss, but nothing excessive. Owners are encourgaed to monitor the oil level frequently, but then again that's just good advice for any new car.
I have an '05 and I haven't put a drop of oil in the last 6k miles since switching over to a synthetic.
My advice is to take it to a mechanic and have him check it out before you lay down your hard earned cash.
Old 06-04-2007, 09:22 PM   #3 (permalink)
The Dude's on the money gogo. There's some talk occassionally about someone experiencin' oil loss, but if you read the posts on the site about that issue, you'll find that they're few n' far between.
When you consider that most of us are drawn to Stewie to wind it up tight n' put it through it's paces while it's hangin' onto the corners by it's fingernails, the fact that there aren't alodda posts citin' oil loss speaks volumes.
Sometimes you godda listen to the silence too.
Old 06-04-2007, 10:10 PM   #4 (permalink)
Agreed with the above, it depends on how the engine was broken in for the most part. I have had mine for over 5 years and have never had any oil burned off.
Old 06-04-2007, 10:55 PM   #5 (permalink)
ottokrat
ottokrat's Avatar
I think break in technique is a big deal. This car is my first S2k. From years of V8s in cars and two-cycle engines in jet-skis etc..., I believe in the "hard break in", but, respected the information on these forums that these engines don't do so well if they spend a lot of time in VTEC during the break in period. So I every so gently and slowly (so as not to shock the drive train) floored it from 2-3k up to 5k rpm many many times in the first 10-150 miles (after fully warmed up of course). For example, on the way home from the dealership on the freeway. Result so far: zero oil burning at all with 10k+ miles on it. We'll see how it holds up over time, but I think its good to go.
However, if you have problems with a used car, consider the Krank Vents solution.
2006 S2000 Suzuka Blue
San Jose, CA
ottokrat is offline   Reply With Quote
Problem With my S S2000GR All Other Honda S2000 Related Discussions 5 01-31-2007 03:58 PM
Diff oil & tranny oil arprice Engine Tech / Drivetrain 6 01-21-2007 02:10 PM
problem someone help chocho All Other Honda S2000 Related Discussions 1 08-30-2006 05:25 PM
Pls help!! Oil leaking problem!! [Pics Included] freestyler All Other Honda S2000 Related Discussions 3 10-24-2005 04:47 AM
Oil Stick to check oil.... kccane All Other Honda S2000 Related Discussions 1 07-04-2004 09:32 PM
