Old 06-16-2007, 12:51 AM   #1 (permalink)
bullet21
bullet21's Avatar
Send a message via AIM to bullet21
Unhappy could use some help here
once i start my 01 s2000 it idles fine for a minute and then starts dipping really low and back up (rpms), it does this for a minute or two and then dips and stalls. No codes are thrown at all though. I tried to reset the ecu by removing the negative cable for a while and then do the "idle learn" proceedure, and then it seemed to idle fine for about 5 minutes after i restarted it, then it started happening all over again. i havent tried the map whack yet, but dont really think it is my problem. I cant even drive the car because as soon as i go to take off and give it throttle it dies as soon as i let off the gas. i figured if it was a sensor (o2 or tps) it should throw a code, right? i am pretty sure its not a vacuum leak because all the vacuum lines look good. i know the pcm's on this car are considered "learning computers" and i have heard alot of people having to reset the comp during climate changes and things like that (info from an s2000 forum). Any advice would be great. thanks
bullet21 is offline   Reply With Quote
Old 06-16-2007, 07:54 AM   #2 (permalink)
Aaay Bull, sorry to hear 'bou'cher problems. I'm not one'a the site technical problem solution guys. Afraid that alodda what I really know about is usually in a bone-yard somewhere, but some ol' techniques still serve us well, so, until our very capable site problem solvers arrive, lemme ask you this: was there any kind' warnin' signs before it went into this situation n', more importantly, was there anythin' engine-wize done to the car recently?
Chances are it probably some black box/computer/sensor/save-us-all-from-ourselves kind'a thing of which I ain't godda clue, but if it ain't . . .
Be well n' keep us posted.
Old 06-16-2007, 11:01 AM   #3 (permalink)
It doesnt sound like an o2 to me. Normally a o2 will make it run ruff at idle but usually doesnt stall and usually you can smell its running way rich at idle. I am really suprised you arent getting a code with it acting like that.
2001 Vortech SC
12.8 at 111 miles per hour
Old 06-16-2007, 11:08 AM   #4 (permalink)
bullet21
bullet21's Avatar
thats why i am stumped, because there is no code at all. it doesnt smell rich either. i have a couple people telling me to check the map and aicv. im gonna try that today.
Old 06-16-2007, 11:55 AM   #5 (permalink)
HELL_ON_WHEELS
HELL_ON_WHEELS's Avatar
I went through the same thing with my '00, I tried everything anyone told me, then took it to the shop turned out to be a simple fix my #1 coil pack need to be replaced that did the trick
"Drive it like you stole it"
Old 06-16-2007, 11:59 AM   #6 (permalink)
bullet21
bullet21's Avatar
even though...
... it idles fine for a little bit after starting and then after about 2 min it will start doing the idle dip until finally stalling, if it is ever given any gas it will stall immediately after letting off the throttle. My starter is almost toast from having to restart it so much. And P.S. I would love to get the service manual in pdf format.
Old 06-16-2007, 12:10 PM   #7 (permalink)
HELL_ON_WHEELS
thats what was going on with me, I changed so many thing people told me to and it turned out to be a 60.00 fix at the shop. it would happen when I would stop at red lights or in traffic it was a pain in the ass, and yes I'll send you a manual just PM me your address I have a few I need to send
Old 06-16-2007, 12:12 PM   #8 (permalink)
HELL_ON_WHEELS
P.S. don't waste much time on it take it to a mechanic you trust and have him take a look he will test the coils to find the one thats going out
Old 06-16-2007, 12:21 PM   #9 (permalink)
See Bull? 'Tol' ya they'd be along shortly.
'Hope Hell'z got'cher problem solved, r' that your mechanic will.
Old 06-16-2007, 12:33 PM   #10 (permalink)
bullet21
bullet21's Avatar
well im usually my own mechanic, but this one has just got me dumbfounded.
Old 06-16-2007, 12:37 PM   #11 (permalink)
HELL_ON_WHEELS
I'm the same way but, you have to know your limits or bad stuff happens
Old 06-16-2007, 01:52 PM   #12 (permalink)
satisaii
Send a message via AIM to satisaii
I would verify that the check engine light is working.
I would pull the plugs and read them. Be sure to torque them properly.
I would put the coils on in a different order than they came off.
I would go and make sure that all the connectors are seated properly.
satisaii is offline   Reply With Quote
Old 06-16-2007, 03:24 PM   #13 (permalink)
bullet21
bullet21's Avatar
Ok guys, tried the map whack, iacv was clean, egr was clean. after that I reset the ecu again and when I was doing the idle learn the "eps" light came on. But no check engine light. What is the eps light?
Old 06-16-2007, 03:50 PM   #14 (permalink)
HELL_ON_WHEELS
thats your Electric Power Steering (EPS) System, now when you start the car does that stay on or shut off (it should come on for a few seconds and shut off when you start your car everytime)
Old 06-16-2007, 03:55 PM   #15 (permalink)
bullet21
bullet21's Avatar
it stays on
Old 06-16-2007, 05:37 PM   #16 (permalink)
HELL_ON_WHEELS
Don't know what to tell ya there (maybe ease off re-setting the ECU for awhile?)
Old 06-16-2007, 05:39 PM   #17 (permalink)
bullet21
bullet21's Avatar
no it didnt, and it didnt once i restarted the car either, it was when i was doing the idle learn that it came on.
Old 06-16-2007, 05:45 PM   #18 (permalink)
HELL_ON_WHEELS
see I had someone walk me though that before and it never helped me either
Old 06-16-2007, 07:02 PM   #19 (permalink)
bullet21
bullet21's Avatar
i dont know, there is a guy off another forum who lives near me who says he will come and help me diagnose it on monday
Old 06-16-2007, 07:32 PM   #20 (permalink)
HELL_ON_WHEELS
Good luck, hope you figure it out
Old 06-16-2007, 07:38 PM   #21 (permalink)
bullet21
bullet21's Avatar
me to. im just so short on cash right now, that i dont want to go and pay a mechanic 90 bux to just tell me whats wrong with it and then whatever money on top of that to fix the problem, you know? i would rather know what it is and then just go and get the part and do it myself or something along those lines.
Old 06-16-2007, 11:25 PM   #22 (permalink)
Yeah Bull, that'd be great if it worked that way, but as a wrench, you know that even in person it ain't always that easy to make a diagnosis. Via the internet . . . well, at best, it leaves somethin' to be desired for us ol' tire-kickers.
Best'a luck Monday. 'Weather's jus' too durn nice ta have it sittin' there.
Old 06-16-2007, 11:31 PM   #23 (permalink)
bullet21
bullet21's Avatar
my sentiments exactly, but it couldnt hurt to have someone familiar with the car check it, also he owns one so i may be able to pull his map sensor and put it on mine to see if its the problem, or his coilpack or whatever we think it could be, ya know?
Old 06-17-2007, 09:24 AM   #24 (permalink)
bobby2002S2K
bobby2002S2K's Avatar
My mech only charges me to fix it not to check it out, i guess i'm just lucky.
Old 06-17-2007, 10:58 AM   #25 (permalink)
HELL_ON_WHEELS
I think thats how most do it
Old 06-17-2007, 10:59 AM   #26 (permalink)
bullet21
bullet21's Avatar
yea, youd be lucky for that. around here we pay a minimum 1 shop hour for diagnosis and then however much to fix on top of that. Ofcoarse i dont have my own mechanic, normally i do it myself, maybe because you r\take it to the same guy or something.
Old 06-17-2007, 12:29 PM   #27 (permalink)
I dunno if I was a tech and I didnt charge to diagnose a problem and then the customer was just like ya I just wanted to know what was wrong so I could fix it I would hope that as they pulled away they were side swiped by a large flaming truck filled with human feces. But thats just me.
2001 Vortech SC
Old 06-17-2007, 01:00 PM   #28 (permalink)
bobby2002S2K
Like you i do alot of my own work but sometimes i got those problems that is really ubove my skill level.So i carry to this guy. But i have had this guy do alot for me like engine swaps and other big jobs.So he hooks me up sometimes like changing cam seals and things like that. You should really look into findin a good mech. It really does help sometimes even if you usually do your own work have someone you can refer people too. that will do them right and that dude will be there when you need him.IDK thats kinda like what i did.
Thats why when
