Bored of stock engine any suggestions??
Hi guys, I've been riding my s2k with its stock engine for a while and decided to tune it up.. I'm planning a turbo but also I want the internals done good. Are there any built up engines sold on the market that I can import and mount on my car without any problems. Thanx.
The Guy
What do you mean by drop in? You mean built for turbo? Built to race? or someone else's project so you won't spend money to make it yourself? If you're going to build it up, send it out. If you don't have money, don't build it. (duh). decide what you want to do with it first. Daily driver, Drag, Autocross, Freeway, Monster tuck, Whatever it is, build it to do one specific thing. We can't have it all so choose wisely. If you do have the money, Have at it! Get 500hp and a locked diff with drag slicks. If you got the dough. Either way, it's better to build it for your needs than have a prebuilt.
It depends on how much WHP you want. Stock internals are fine for less than 400WHP, but you may need to put in a lower compression head gasket. A turbo is expensive and without a proper tune, can REALLY shorten the life span of your engine.
The SC kits that are available run as bolt on kits and do very well, but will only get you around 300 WHP. Again, it depends on what you want. |
"Only get you around 300 WHP"? . . . . (Sigh)
That's a pretty substantial "only" Go. Maybe for straight-line contests it might be lacking, but with the rest'a Stewie's credentials, 300 WHP sounds like what should'a been under the hood from the get-go. That sounds like a way'da go (IMHO). Be well. Java |
So java it seem like lately youve been hot for power so whens the blower getting bolted on?
if you have about 15 grand i can get you a fully built 2jz supra motor in there with 900 hp, installed, it comes with a silvia rear and produces supercar power, pritty much untouchable. period. thats the ultamate cant touch this motor swap for the s2k, or i saw a guys s2 the other day with an LS2 vette motor in it, it was sick man, 460 to the wheels and only weighed 189 lbs heavieer than the stock motor so the weight didnt change much for what he did, but he had to havily mod the frame, still it was amazingly put together.
why not use a ls7? I am not a fan of the supra swap. Just seems like bragging rights on the dyno to me but to each his own I guess.
Stewie's lackin' in only one area (N' no. It's not the power tonneau cover). Stewie's credentials r' impressive, but we've all seen it as a topic of too many posts to be jus' idle talk: Stewie jus' doesn't have power relative to the rest of it's runnin' gear.
Stock, Stewie's a sweet package, but there's never a time when you come away from a serious session'a pushin' it without feelin' that it could really benefit from a substantial chunk'a additional power. That said, when "improvin' it", it can come a point when, if you fail to step back n' look'it where it is you wanna be goin', you can turn a graceful epee into a clumsy claymore. I've always admired the attributes of Stewie, n' I'm all for enhancin' 'em, but what good does somethin' like a 2Jz, a Hemi, r' any weighty big block engine if it's providin' power that can't be hooked up n' the extra weight takes away from the car's most basic intention: layin' waste to chicanes. To me, anyway, it ain't about braggin' rights, bench racin', the challange of fittin' a square peg in a round hole, parkin' lot hood'zupp show-me-yours-n'-I'll-show-ya-mine, r' tire smokin' contests: It's dealin' with those durned twisty roads that keep poppin' up all'a time. But this is my personal poison. As isu so correctly puts it: "To each his own". (Soon isu. 'Big case'a godda) Be well. Java |
guys I have just found out that due to the custom regulations, easiest place to import an engine is Germany. Do any of you guys know a place, shop, company,whatever that I can get an engine shipped from in Germany? I got around 7 or 8 grand for this and I really dont need 900hps
I suspect that the Corvette LS2 isn't a 283 r' a 327 FI. Probably the Cheetah engine, right?
LS2? Now what's an LS2? (Dunno whut it is, but I jus' love when Chevy talks like that) Be well. Java |
LS2 is the motor from the 06 corvette. The new corvette motor is a ls3
I can appreciate that isu, but what's the current C.I. that the 'Vettes r' runnin'? I know this is gonna be a major guffaw, but, last I heard'a 'Vettes was 350s with slant plug heads. 'Guess it's been awhile.
So what's the LS2 spec? N' what's so special about the LS3 that it's replacin' the LS2? (Yeah, I know: Bigger! Better! Improved!) Thanks n' be well. Java |
Honestly I dont like chevy hahaha. But I dont know how many c.i never read up on how much gm said the zo6 was 427 cubic inches but I dont recall seeing the ls2. From what I heard the ls3 has a little more power but I dont think it was a huge jump. I personally think theyre gonna use the ls2 in the camaro and they couldnt have the same motor in the vette and camaro. Mind you I am talking totally out of my rear and for all I know they have already published what motor is going in the camaro and I am way off.
#16 (permalink) |
wohhh....java, im a hardcore honda boi too, i also belive like you to not change alot.you wont catch me pulling my boosted F20 outta the bay any day.
#17 (permalink) |
Aaaaay Kman!
I kind'a figured that that's what was goin' on, but, by now, you guys know that if I can write a book when only a few words're necessary . . . 'Godda admit that what I saw of the 2Jz swap that was on the site for a bit looked like real quality work. 'Made me wanna go out n' get heavily inta rubber investments, y'know? N' for the record: except for my appreciation of Stewie, I'm not really fond'a Honda (fond'a Honda . . . gedditt?) I'm ol' school Ford blue oval by heritage (My dad was n' that's jus' how it goes, don'cha know?) but until such time as Ford sees it's way clear to build a light, cornerly appointed 2 seat roadster . . . yeah, not bloody likely. (Does anybody remember the original Mustang that previewed at the shows before the street-goin' version showed up in showrooms back in '63/'64? It was a rear-engined 2 seat roadster with proportions remarkably similar to a certain German rear-engined sportscar. Okay, okay . . . so it was a 2 seater n' it had it's engine in the rear. Should'a/would'a/could'a.) Be well. Java |
